Thread: ABS fault cracked fuse my first forum fix
  1. ABS fault cracked fuse my first forum fix
    May 2017
    South Bucks england
    Had the dreaded ABS light on and off over last 2 weeks coming on with ignition randomly staying on between 1 and 5 journeys then going off .Doesn't seem to be any pattern to it except it only comes on at start of journey at ignition start and only goes out about 15 seconds into journey.Inspected the bonnet fuse and there's a fine crack so ordered a replacement. Don't know if it will solve the problem but got everything crossed. Many previous threads on here and had I not of joined up wouldn't of been any the wiser.Forums are a great source of info especially when you first buy a car and over many years have gained lots of knowledge on various cars but totally uneducated on your new purchase so thanks to all members new and old
  2. Re: ABS fault cracked fuse my first forum fix
    Dec 2014
    Bedford
    42 Post(s)
    It's a common problem. Replace the fuse. Then cross fingers. If it continues to blow then its likely to be the abs pump.
  3. Re: ABS fault cracked fuse my first forum fix
    1840 Post(s)
    They have been cracking since the Polo 9N came out in 2002, I remember the first time I had one in with it. The car was just out of warranty and the dealer wanted £1K for a new pump and the owner asked me to take a look. I put that fix in my column in a now defunct magazine called "The Golf" in 2005 which feels like yesterday....
  4. Re: ABS fault cracked fuse my first forum fix
    Dec 2014
    Bedford
    42 Post(s)
    I would be happy to continously replace the strip fuse. ...forever.
  5. Re: ABS fault cracked fuse my first forum fix
    May 2017
    South Bucks england
    Well fuse came Saturday dinnertime fitted Saturday afternoon light went out when I drove off .stopped restarted car and drove off 5 or 6 times ABS light lit up at ignition check as expected but went straight out same again today so I think it's FIXED whoopee. It's an easy fix once aware that the fuse has cracked. Thanks all.
    1 2 0
  6. Re: ABS fault cracked fuse my first forum fix
    1840 Post(s)
    Dug this off of a backup CD I had in my desk draw at home, it was dated 3/03/2004 which was just after my 40th birthday when Mother of Crasher bought me my first digital camera.
    Notice how fuse 5 and 6 (ABS) are cracked (they are not always this clear), I can't remember the car but it must have been a petrol (no glow plug fuse at position 4) with AC (so probaly a 1.4) as the fan fuse (5) is also cracked, another common problem also on the Golf 4 V5/V6 and 150 TDI with the larger fan.
    As the date sticker shows 07/02/02 the car can barely have been 2 years old so I can't think why I had it in?
  1. A* Suspension not raising no fault code fuse ok!?
    By planetnz in forum A8 - S8 - V8
    Last Post: 20-12-2015, 07:51 AM
  2. Question Heater Blower Fault / Fuse 25
    By Josh2109 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-12-2014, 09:42 PM
  3. Please Help Audi A3 2003 / 53 Reg fuse fault
    By jamiemancuk in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 05-05-2013, 10:27 PM
  4. Air Con Fuse blown and ESP fault - 3.0TDi
    By seventh-heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-01-2013, 03:54 AM
  5. Intermittent fault, where does fuse 29 live?
    By roguevogue in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-09-2011, 08:07 PM
