Thread: 2017/2018 Map update available
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 63
  1. Re: 2017/2018 Map update available
    Apr 2016
    berkshire
    39 Post(s)
    Quote Originally Posted by anemeth View Post
    8kB is defenetly wrong for the map, the file you downloaded is JNPL file type. You should run the file (hopefully your Java is uptodate on your PC). When you run the file a Java applicaton should come up called Audi Connect Download. This will ask you where (which directory) to download the map to. After you tell it, than it will start the download.
    Will try that later as IE had the same story, I know chrome have dropped java support (Napi Plugin) for a while now so thought that too..
    Will double click the files to see what happens..
    Sent from my PLK-L01 using Tapatalk
  2. Re: 2017/2018 Map update available
    Apr 2016
    Stansted
    169 Post(s)
    Once you've downloaded the jnpl file, the browser shouldn't come into play but the version of java installed would do.
    I run mine from a Mac with the latest java installed.
    Former Q7 owner
  3. Re: 2017/2018 Map update available
    Apr 2016
    berkshire
    39 Post(s)
    Hi Fella, thanks , that's right double clicking wasn't invoking the java applet on one pc so tried another..
    Works now
    The FULL one is appx 13.gb
    I take it just follow the instructions on in the AUDI once on the SD card? does it need to be on the ROOT folder or anything?
    Thanks again Rgds
  4. Re: 2017/2018 Map update available
    Apr 2016
    Stansted
    169 Post(s)
    Hi mate, yes the folders / files that it extracts should go in the root of the SD card. Probably needs to be blank or at least have nothing left on it from any speedcam / spoi uploads at least.
    Then just follow the system update menus and it should do its thing!
    Former Q7 owner
    1 1 0
  5. Re: 2017/2018 Map update available
    Feb 2014
    Camberley Berkshire
    13 Post(s)
    Hi, worked a treat via SD Card for me today, and the poster who wonders about the Coral Reef roundabout update can now be happy that the map now correctly displays the new road design.
    I noticed that England South seemed to be available for online download today too if it helps anyone.........
  6. Re: 2017/2018 Map update available
    Apr 2016
    Stansted
    169 Post(s)
    No news on England North (aka Scotland) then?
    Former Q7 owner
  7. Re: 2017/2018 Map update available
    #17
    Feb 2014
    Camberley Berkshire
    13 Post(s)
    Quote Originally Posted by srbsq7 View Post
    Where the heck is that? 🇬🇧😜
  8. Re: 2017/2018 Map update available
    #18
    Jun 2017
    New user, so first post! I also had hassle on downloading on a windows PC as Windows 10 and the Edge browser was giving me hassle. Worked fine on the Mac. I downloaded the full 13Gb upgrade as my car already had all of Europe installed and the on-line update only wanted to give my immediate region and not the whole UK.
    As long as you drop the files in the root of the SD card it works well and took about 30 minutes to update in the car.
    Cheers,
    JonnJ
  9. Re: 2017/2018 Map update available
    #19
    Apr 2016
    Stansted
    169 Post(s)
    Glad you got it sorted. I think Microsoft dropped support for Java in Edge.
    Former Q7 owner
  10. Re: 2017/2018 Map update available
    #20
    May 2017
    Reading, UK
    23 Post(s)
    Yup, along with other plugins - IE11 should still work if you're not a chrome user though.
  1. (S)Q7 MIB2 MMI Official Update - April 2017
    By andyhud007 in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-10-2020, 10:06 AM
  2. 2017 UK, Europe map update
    By jangles in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 28-09-2017, 12:14 PM
  3. New SatNav SD card 2017 update has appeared
    By vince47 in forum Passat - B8 Forum - 2015 -
    Last Post: 18-08-2017, 02:45 PM
  4. Nav update 2017 Maps for just over £100.00
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-04-2017, 07:42 PM
  5. Latest Map Update 2016/2017 - Not showing on MyAudi
    By ChuckMountain in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-03-2017, 02:22 PM
