Thread: 1.9tdi B6 passat
Results 1 to 10 of 11
  1. 1.9tdi B6 passat
    Jun 2015
    Hillsborough
    Thinking of buying one of the above and just wondering everyone's opinion on the 1.6 engine. Currently got a 2.0tdi 140. Are they a good reliable engine? Thanks in advance
  2. Re: 1.9tdi B6 passat
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Title says 1.9 but post says 1.6? The 1.9 is not bad and seemingly more reliable than it's 2.0 sister engines, but try to steer clear of ill maintained BXE engines as they have a tendency to pop a con rod through the block when the big end shells seize. BKC is the more robust version and BLS ok but still not entirely unaffected by the BXE problem. There are still thousands of well maintained BKC, BLS and BXE engines out there and some have had preventative maintenance performed on them to renew / upgrade the shell bearings. Most well maintained 1.9 units run well.
    Mad Mitch
  3. Re: 1.9tdi B6 passat
    Pembrokeshire
    22 Post(s)
    b6 passat, 1.9, rather you than me. every expensive fault that a car can have.
    0 2 0
  4. Re: 1.9tdi B6 passat
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Starting with the epb rear calipers if they havent already been changed!
  5. Re: 1.9tdi B6 passat
    Pembrokeshire
    22 Post(s)
    followed by the steering lock.
  6. Re: 1.9tdi B6 passat
    Dec 2014
    Bedford
    42 Post(s)
    Also the handbrake switch and ac compressor also the ac pressure switch then the dmf. Then the turbo which in fairness may get away with a good clean out.
  7. Re: 1.9tdi B6 passat
    Dec 2014
    Bedford
    42 Post(s)
    Dont forget the injectors. Plus the lift pump...but hopefully they have already been replaced by now.
  8. Re: 1.9tdi B6 passat
    Dec 2014
    Bedford
    42 Post(s)
    Front shock absorbers. Lower arm bushes.
  9. Re: 1.9tdi B6 passat
    Dec 2014
    Bedford
    42 Post(s)
    Inner door handle cables
    1 1 0
  10. Re: 1.9tdi B6 passat
    Jan 2012
    10 Post(s)
    87 Post(s)
    Seems I may be getting confused with the B5 which is a very good car. Always thought the 2 litre version of the B6s were the ones to avoid (like the one I have) but apparently I am mistaken.
    Mad Mitch
  1. Please Help vw passat 1-9tdi
    By graham 1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2015, 03:28 PM
  2. Please Help 2003 1.9tdi pd passat
    By 6712chrisp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2011, 10:07 AM
  3. Please Help My first VW. Passat S 1.9TDI 105
    By k2jamrock in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-02-2009, 08:57 PM
  4. Question 05 passat 1.9tdi will not start
    By mellorcars.net in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 04:45 PM
  5. pressurizing vw passat 1.9tdi
    By crow3030 in forum New Member Introductions
    Last Post: 24-03-2008, 09:08 PM
