Thread: MOT adivsory - play in steering rack inner joint?
  1. MOT adivsory - play in steering rack inner joint?
    May 2017
    Norwich
    A little advice needed. I've seen an Audi A4 B8 2008 which I'm interested in buying with only 64000 on the clock. Two advisories on the MOT in June 2013 and June 2015 showed 'Play in steering rack inner joint(s)'.
    Funnily enough there's no entry for it in the June 2014 or June 2016 or April 2017 MOT. So my question is:
    Is this a known fault? Are the garage just being over zealous and finding something which isn't there? And if there is play in steering rack inner joint is this an expensive fix?
    Any help greatly appreciated.
  2. Re: MOT adivsory - play in steering rack inner joint?
    Pembrokeshire
    22 Post(s)
    common thing to do, replace the track rod end and gator at the same time and get the tracking re set. 50 ish quids for the parts aftermarket. it might have been replaced following the mot, hence not seeing it again.
  3. Re: MOT adivsory - play in steering rack inner joint?
    May 2017
    Norwich
    Thanks zollaf - Audi 80 with 357,000 miles!!! Wow!
    Anyhow, as long as it doesn't mean a new steering rack
  4. Re: MOT adivsory - play in steering rack inner joint?
    Pembrokeshire
    22 Post(s)
    must update, 360,000.
  1. Play in steering rack
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2012, 07:41 PM
  2. MOT fail - steering track rod inner ball joint excessive play
    By Sly in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-11-2011, 07:26 PM
  3. LT 28 steering rack play
    By rsitup in forum The Commercial Range
    Last Post: 08-05-2009, 08:44 PM
  4. Please Help 2000 2.5TDI T4 Steering rack end play
    By Anthony Bigwood in forum The Commercial Range
    Last Post: 29-11-2008, 12:09 AM
  5. Advice needed - possible steering rack / cv joint / gear box problem
    By angel18082005 in forum Chat - Anything with wheels
    Last Post: 13-09-2007, 06:55 PM
