Thread: Bonnet open and boot open warning beep
  1. Bonnet open and boot open warning beep
    May 2017
    Norway
    Hi everyone
    I have a 2005 1.9 tdi b7
    Just changed the front slam panel after a crash and now i get these warnings
    Firstly the bonnet open problem , i know there is a microswitch inside the latch , i have removed the connector behind the radiator fans and i still get the the warning , the connector i removed was only for the microswitch. If i remove the main connector close to the power steering fluid resevoir the warning goes away. I dont understand why it doesnt go away after removing the plug for the microswitch
    Then the boot open warning , nothing helps besides removing the plug on the boot latch , but then i wont get to open the boot. I did remove the connector while the boot was open and yes the warning did go away
    Can anyone help me?
  2. Re: Bonnet open and boot open warning beep
    Sep 2008
    chester
    17 Post(s)
    I would say it depends whether the contacts are no or nc .
  3. Re: Bonnet open and boot open warning beep
    May 2017
    Norway
    Quote Originally Posted by nevo View Post
    Could you elaborate please? The new slam panel had a different type of connector and only one radiator fan not two like the old one. So i cut it off and soldered the old connector to the new wiring. If i remove the connector i dont get the warning but there are only 2 wires for the sensor 5 other wires go to other things so i cant keep connector removed
  4. Re: Bonnet open and boot open warning beep
    Sep 2008
    chester
    17 Post(s)
    the micro switch will ether complete a circuit when the bonnet is shut or break it.
  1. Replies: 0
    Last Post: 08-01-2012, 09:05 PM
  2. Please Help A3 Boot Open Warning
    By MattyBoyR in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-11-2011, 01:06 AM
  3. Snapped bonnet cable - how do I open the bonnet to replace it?
    By golfdti in forum Golf MK3 - 1993 - 1999
    Last Post: 20-04-2009, 08:12 PM
  4. Bonnet catch sensor thinks bonnet open when it isn't
    By paddtg63 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 08:06 PM
  5. bonnet open warning
    By DAK1471 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2008, 11:35 AM
