Thread: Touran AC fault
Results 1 to 10 of 20
  1. Touran AC fault
    Cornwall
    I am currently investigating a fault on my 04 Touran TDi, see below. I have a good ground on pin 1, but nothing on pins 2 or 3. 3 is supply I believe and 2 is signal return.
    My problem is that I do not have any wiring diagrams and need to know the source of the supply and its route, i.e. via a relay perhaps?
    Would someone please be able to assist? In addition, are the Haynes manuals worth the £15 investment, or are they rather useless?
    Many thanks
    Code:
    Thursday,18,May,2017,19:47:32:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    VIN: WVGZZZ1TZ4W089518   License Plate: WJ54YHR
    Mileage: 142460km-88520mi   Repair Order: Scan #3 Post code clear and battery
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
    VIN: WVGZZZ1TZ4W089518   Mileage: 142460km-88520miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 A    HW: 028 101 073 1
       Component: R4 1,9L EDC 0000SG  5185
       Revision: 12345678    Serial number: VWZ7Z0C8620022
       Coding: 0000072
       Shop #: WSC 01324 785 00200
       VCID: 2143D924F85EBB49C6-8074
    1 Fault Found:
    18049 - Please check DTC Memory of A/C Controller
                P1641 - 000 -
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 2.0 Nm
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 12.31 V
                        Bin. Bits: 00000000
                        Temperature: 18.0∞C
                        (no units): 144.0
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0021190
       VCID: 3A710E4875C8C891E7-806E
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   060 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C98A3851F09C7173-8032
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
                009 - Open or Short to Ground
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H29 0701
       Revision: 00029000    Serial number: 00000000326141
       Coding: 00890F020004100000120C000000000000
       VCID: 3777177C46DAD5F918-8062
       Subsystem 1 - Part No: 1T0 955 119 B  Labels: 1TX-955-119.CLB
       Component: Wischer WWS A-MPV   0201
       Coding: 16711828
       Shop #: WSC 00000
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605     HW: 1T0 909 605
       Component: 05 AIRBAG VW62 0506 2112
       Coding: 0012341
       VCID: 72E1E6686D3870D1EF-8026
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549     HW: 1K0 953 549
       Component: Lenks‰ulenmodul 012 0030
       Coding: 0000002
       VCID: 6FE7EF1C7E0A5D3900-803A
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1T0 920 950 G
       Component: KOMBIINSTRUMENT VDD 3550
       Coding: 0003401
       Shop #: WSC 00278 067 57207
       VCID: 356B1D745CD627E90A-8060
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 M
       Component: Zuheizer        020 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
       Shop #: WSC 00278 210 02721
       VCID: 2F672F1CBE8A1D3940-807A
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100103A142EBB
       Coding: 3D0F1340078003
       VCID: 2757C73C967A457988-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3550
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1T0 959 701 C
       Component: Tuer-SG         024 2402
       Coding: 0000756
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 L
       Component: EPS_ZFLS Kl.0       0402
       VCID: 336F236C52A239D924-8066
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0201
       Coding: 00E802087F2D8404085B0100
       VCID: 30652C60A3B402C159-8064
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1T0 959 702
       Component: Tuersteuergeraet 09 0111
       Coding: 0000052
       VCID: 75EBDD741C5667E9CA-8020
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 G
       Component: Radio BNO           0013
       Coding: 0020200
       VCID: 2A513E088568781197-807E
    1 Fault Found:
    00003 - Control Module
                014 - Defective
    End-------------------------(Elapsed Time: 01:31)--------------------------
  2. Re: Touran AC fault
    Cornwall
    In addition, my fuse layout is in the pics below.
  3. Re: Touran AC fault
    Jul 2015
    Staffs
    46 Post(s)
    Have you replaced the G65 sensor?
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: Touran AC fault
    Cornwall
    No, not yet.
    I want to make sure that the wiring is correct before replacing components.
    So far, I don't have power where I think I should, hence the need for diagrams.
  5. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    G65 first. Then clear faults. Then run it im assuming its fully gassed. Max cooling ac on. If its still no good measured values vcds look for compressor status coding. Get the code as this will pinpoint why compressor duty cycle is off. Post it. I will help further. When you change g65 just remove wiring plug and unscrew it you wont lose any refrigerant. I do wonder though as in that log it shows output at 2 newton metres... i can and usually fart harder than that.
  6. Re: Touran AC fault
    Cornwall
    Thank you for your help, but if I do not have a power supply to the G65, is it likely to make any difference if I fit a new sensor?
    I do not have the diagrams, but I'm assuming that VCDS is looking for a signal return on the CAN bus from pin 2. There is no power, so no signal, hence the blank in the AC pressure in measuring blocks, not even a zero.
    I suspect a relay rather than a fuse, or perhaps a splice somewhere, as it seems that this is the only AC fault. A total power failure from a ruptured fuse would likely give a different fault code.
    Is 2Nm not the measured engine torque at that point in time?
  7. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    If there is a code condition for ac shut off then there will be no power to the ac compressor plug is the way i see it with boardnetz. Just as when a bulb blows it shuts power supply. Actually thinking about it 2nm is with no revolutions. As shown in your log. Do you have vagcom or something that can read measured values?
  8. Re: Touran AC fault
    Dec 2014
    Bedford
    42 Post(s)
    Just double checked, yes no power supply to compressor if there is a cut off code. Go to 08 hvac then measured value block 1 field 1 what 2 digit code is shown. Do this with engine running ac on max cooling.
  9. Re: Touran AC fault
    Cornwall
    17.0 Compressor shut-off code.
    So are you saying that if the compressor receives a shut-off code, no power is supplied to the G65 switch? If this is the case, how does the system know there is a fault with G65?
    I'll just run the scan again, but with the engine running as suggested. I'll post the screen grab and/or log.
  10. Re: Touran AC fault
    Cornwall
    I have no idea how much gas is in the system. I'll get it booked in for a check.
    The way I imagine the system to work, is that the pump will be given the shut-off code from the G65, but this switch would need power to give an "on" signal and no power would show as a short or open switch, just as you would expect if the switch were operated because of a high pressure situation. Without more in depth system info, or a wiring diagram though, I am somewhat scuppered.
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. Question Touran ecu fault
    By christopher1970 in forum Touran - Sharan - Caravelle
    Last Post: 09-04-2013, 04:47 AM
  3. touran 1.9 tdi starting fault
    By tractor fixer in forum Touran - Sharan - Caravelle
    Last Post: 27-02-2010, 05:52 PM
  4. vw touran 1.9 tdi start up fault
    By tractor fixer in forum New Member Introductions
    Last Post: 20-02-2010, 01:57 AM
  5. touran fault codes ?
    By itsshreck in forum New Member Introductions
    Last Post: 14-12-2009, 03:13 PM
