Thread: A4 avant wont start
  1. A4 avant wont start
    Jul 2016
    Wrexham, North Wales
    New to this so apologies if I get it wrong.
    Fitted fuel filter, badly, didnt fill with diesel so airlocked, got started eventually, tubes weren't tight so another airlock.
    Now will start in morning and most of day (5 or 6 times) then wont start. Called out AA he tried hand pump but couldnt get fuel, so turned it over again and it started. Back home now and dont know what to do.
    Any suggestions?
    Also why supplementary pump? How do I know if its working properly?
  2. Re: A4 avant wont start
    Jul 2007
    glasgow
    34 Post(s)
    it should self bleed over a week , 2 to 3 days is not uncommon .................. might be slow to start but should fire up
    You could take off the filter and fill it up, did you replace the O rings on the connections ?
    Are the pipes on correctly ?
    You could smear Vaseline on the pipe connections incase air is being drawn in at filter
    I take a photo with my phone before andcheck after for any job that I am likely to get confused on
  3. Re: A4 avant wont start
    Jul 2016
    Sorry bleed problem corrected itself, now wont start when hot. Under 70 degrees starts no problem, 90 degrees no start. Replacing coolant temperature sensor.
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. 1996 A4 TDi se Avant just stopped and now wont start
    By Chris Beagley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2013, 10:21 AM
  3. A4 Avant Sport 1.9 TDI wont start !
    By icebreaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2011, 07:53 PM
  4. Wont Start A6 2.5 Quattro Avant (2000) AKE
    By PapaLarge in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-10-2009, 08:52 PM
  5. Please Help A4 avant 130 tdi boost problems now it wont start?
    By avantben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2008, 09:09 PM
