Thread: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
  1. A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    Feb 2011
    Cirencester
    Hi all
    I have an Audi a6 c6 2006 3.0 TDI and Im getting a lot of white smoke once engine is warmed up.
    Here atttached my logs for all injectors including groups 72-77
    If someone could give me some advice it would be much appreciated.
  2. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    Feb 2011
    Cirencester
    And one 1.jpgmore.
  3. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    Jan 2014
    Porsgrunn Norway
    I had same problem
    injektors was checked and ok
    but the problem was the injektors��(3,0tdi 2006,BMK engine)
  4. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    May 2014
    Darlington
    78 Post(s)
    As above bad injectors, sometime the ECU values don't tell the full story.
  5. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    May 2008
    40 Post(s)
    Same thing happened to wifes old A4 3.0 tdi quattro, start of the clues were it took slightly longer to crank before starting, then a few months later white smoke whilst idling in traffic.
  6. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    Jul 2015
    Staffs
    46 Post(s)
    I guess the ECU can only check the electrical tolerances of the injectors. Say an injector is physically worn, and it drips a bit of fuel, that isn't going to get picked up by a scan.
    All the symptoms point to the injectors.
    Ian
    A4 B6 Avant Nogaro Blue
  7. Re: A6 C6 2006 3.0 TDI - White smoke, New turbo, EGR Cleaned, Injectors checked
    Mar 2009
    Montenegro
    13 Post(s)
    Coolant level is constant? Maybe EGR cooler is leaking? Anyhow, is there some injector leakage, its value in vcds should go to big minus.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  1. Replies: 5
    Last Post: 17-08-2015, 09:52 PM
  2. Replies: 17
    Last Post: 07-03-2014, 02:27 PM
  3. Replies: 18
    Last Post: 04-01-2013, 10:47 PM
  4. 2006 t5 1.9 tdi, white smoke on start up
    By chicargo in forum The Commercial Range
    Last Post: 08-08-2009, 11:42 PM
  5. 97 a4 1.8 turbo white smoke
    By spjmm0 in forum Audi A4 - Archive Topics
    Last Post: 31-07-2006, 02:57 AM
