Thread: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
Results 1 to 8 of 8
  1. Exclamation Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    May 2017
    London, UK
    Hi all
    I have been reading the forum for a while now but posting for the first time. There seem to be many experts here, I am hoping to get some advice on an issue with my car.
    I have recently bought a VW Passat from Cargiant. I have had this terrible vibration noise since day 1 and Cargiant couldn't find anything on two occasions. I have also showed it to my local garage and they can't seem to find a reason behind it. The garage told me that they have checked for any loose fitting but couldn't find anything. The noise comes when the car reaches 2,000 RPMs on sharp acceleration. I hear it almost every time I need to overtake or joining the motorway. It will vibrate for a second or two and then go away till I drop RPMs and accelerate again. I have booked the car for Alan Day VW diagnostics but I am not sure if they will be able to locate this kind of issue. I hope someone here can help me before I waste my money with them. I have uploaded a video on YouTube with clips joined together. Look for the timeline at:
    00:01 - 00:02
    00:04 - 00:04
    00:06 - 00:06
    00:11 - 00:11
    00:16 - 00:16
    00:24 - 00:25
    Appreciate your help with this. Thanks.
    Vibration and Noise from VW Passat 2.0 TDI - YouTube
  2. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    Jan 2016
    Winchester Hants
    29 Post(s)
    Flywheel.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    May 2017
    London, UK
    Thanks UMEL. That would make sense as I had a clutch failure so recently had clutch assembly, dual mass wheel and sleeve cylinder replaced by the local garage. Do you think the fitting wasn't done properly or the garage put a dodgy one?
  4. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    Jan 2016
    Winchester Hants
    29 Post(s)
    Well, I would say that IS the problem.
  5. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    Pembrokeshire
    22 Post(s)
    you buy car, it has vibration. clutch fails, you have new clutch and dmf, vibrations still there same as before. i think its probably not the clutc or dmf then .. ???
  6. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    May 2017
    London, UK
    Thanks guys. Yes, the noise was there when I bought the car. Would it be dangerous to keep driving the car on the motorways? This engine noise only comes when accelerating sharply and when the car reaches around 3000 RPMs. I found that I can avoid the noise, If I accelerate very carefully.
  7. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    May 2012
    Everywhere
    308 Post(s)
    How far in ownership did the clutch go ?
  8. Re: Vibration Noise from recently acquired 2012 Passat 2.0 TDI
    May 2017
    London, UK
    The clutch broke within a month of purchase and it's been a couple of weeks since the change.
  1. Question 2012 2.0 Passat bluemotion ticking noise
    By veedubdan in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-10-2016, 09:59 AM
  2. Recently acquired Audi 80 cabriolet
    By Daniel Andrews in forum 80 - 90
    Last Post: 06-06-2015, 08:12 AM
  3. Please Help Touran 2.0 TDi 2012 Clutch Vibration
    By Skillendapsus in forum New Member Introductions
    Last Post: 03-03-2014, 10:07 AM
  4. Please Help RCD510 recently fitted in to 2007 passat
    By Granster in forum In Car Entertainment
    Last Post: 14-09-2010, 06:40 PM
  5. vw passat vibration noise and feel
    By gosp2004 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 01:48 PM
