Thread: Raising Revs at motorway speed?
  1. Raising Revs at motorway speed?
    Jan 2012
    London
    Hi Guys,
    Have a 2011 A4 2.0TDi manual.
    Car has circa 130k miles on it. Recently it has started to develop an issue. When cursing at say 70mph in 6th gear and flooring the accelerator, the revs will jump up instantly, they will bounce up and down whilst car is gaining speed and will then stabilise when foot is let off the pedal a little.
    Only happens at higher speeds and higher gears, cannot be repeated in 1st,2nd or 3rd gear.
    Almost like a slipping clutch, which I had two gauges investigate but found nothing. On top of this, over the last two days i noticed a oily patch on my driveway from what seems to be under the gearbox.
    Any suggestions as to what this could be?
    Many Thanks
  2. Re: Raising Revs at motorway speed?
    Jan 2012
    London
    bump?
  3. Re: Raising Revs at motorway speed?
    Pembrokeshire
    22 Post(s)
    your clutch is slipping, fit a new one.
  4. Re: Raising Revs at motorway speed?
    Jan 2012
    London
    Had two garages look into this, both said not clutch. No errors either. Could it be throttle body related?
  5. Re: Raising Revs at motorway speed?
    Pembrokeshire
    22 Post(s)
    speed stays the same, engine revs increase, its a manual gearbox. either the clutch is slipping or the wheels are spinning. 2 garages might say its not the clutch, but it is the clutch cos it cane be anything else. its simple physics. if it was an old volvo 340 with its belt drives then you could put it down to those, but its not, so it isnt.
  6. Re: Raising Revs at motorway speed?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    +1above, clutch slipping, it might be related to the oily patch, having oil on the plate causing it to slip then bite, bouncing the revs. do you notice a burning smell after this has happened? You've had over 100k out of this clutch so not too unexpected?
  7. Re: Raising Revs at motorway speed?
    Jul 2007
    glasgow
    35 Post(s)
    Park the car on a steep hill
    Put the car in 3rd gear and try to take away, with a slight increase in engine speed
    It should stall right away
    Always use a handbrake at traffic lights etc & you should check your brake fluid levels to see if clutch is losing fluid
  1. A4 AVANT 1.8T vibration at motorway speed
    By FT08 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2009, 09:49 AM
  2. Motorway speed cabin vibration. Again.
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 08:13 AM
  3. Wobble when driving at motorway speed
    By PDL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-07-2008, 09:40 PM
  4. hi idiling speed, hi revs
    By gogi in forum Other Models
    Last Post: 27-06-2008, 12:21 AM
  5. revs and idel speed problems
    By Hawk in forum Audi A3 - Archive Topics
    Last Post: 29-01-2007, 02:38 PM
