Thread: Egr failure help.
  1. Egr failure help.
    May 2017
    Wirral
    Audi 8P 2.0cr CFFB. Limp mode with code p0403.
    I have tested the N75 solenoid and the egr solenoid.
    egr solenoid was fine, N75 was at 16ohms, not sure if that's a bit low and if it would effect the egr.
    My question is can you remap the Egr out without actually removing the egr, as many people know it's a pig to get at on these engines.
    Thanks.
  2. Re: Egr failure help.
    May 2012
    Everywhere
    308 Post(s)
    Is it vac line or electronically actuated ?
  3. Re: Egr failure help.
    May 2017
    Wirral
    Sorry to sound really stupid but it has an electronic plug and a vac line, it's the egr that's attached to the cooler.
  4. Re: Egr failure help.
    May 2012
    Everywhere
    308 Post(s)
    Cooler end is probably vac , egr probably electronic .
    If you remap egr out it should remain closed , electronically unplug anyway .
  5. Re: Egr failure help.
    May 2017
    Wirral
    Thanks for the replies.
    Can the remap take place with the egr remaining on the car?
    Also is there any way to adapt the egr values using Vag Com?
    could a blocked cooler (seems to be common) cause this error code do you think? Or a failed n75 solenoid
    does anyone know the spec of that solenoid, what resistance should be across the coil?
  1. Water Pump Failure / Cam belts failure
    By Fly100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2014, 11:36 AM
  2. DRL failure
    By niv2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-11-2013, 07:25 PM
  3. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
  4. Question DSG failure
    By atomickittykat in forum New Member Introductions
    Last Post: 02-10-2008, 09:41 AM
  5. MFD failure
    By Mav2006 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2008, 01:14 PM
