Thread: 2.5tdi v6 AKE -01 camshaft problems
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 2.5tdi v6 AKE -01 camshaft problems
    1836 Post(s)
    All four cams are different but I don't know the measurements. I checked all the manufacturers listed against the cam kit and non give any specification, hardly even a grainy picture.
  2. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    Problem Solved! Now it runs smooth and responds to the throttle really good.
    The problem was that the valves had been too long when they regrinded the head, and that the eBay stuff don't got the best quality.
    So firstly I measured how much the valve was left open, by slowly unscrew the bolts and nuts for the cam and simultaneously doing a leakdown test. And that shown that the space was as biggest 0.75mm on some of the valves. Then I opened a valve lifter and measured how thick the bottom was. I think this China stuff was about 1.7mm thick. And then I started to machine theses lifters 1mm in the bottom with a emery and a screwdriver. Then finished with a smooth file to get a nice surface.
    The valve lifters are not moving when the engine is running, so there are no risk of wear due to the rough surface, the only other place I can figure out is to shorten the top of the valves, but that's much more tricky unless the head is removed.
  3. Re: 2.5tdi v6 AKE -01 camshaft problems
    1836 Post(s)
    It could be that the seats have been cut too deep but it is more likely that the longer (by 0.1-mm) valves of the roller tappets model have been fitted, are the fingers flat or roller?
  4. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2017
    Sweden
    They arr flat, maby ist a combination of faults since the valves was about 0.75mm too long to seal, without any adjustment ability in the hydraulic tappets.
  5. Re: 2.5tdi v6 AKE -01 camshaft problems
    May 2022
    alicante spain
    Quote Originally Posted by GrimNorell View Post
    sorry can i ask a question i have the same engine and car my car went to bosch garage
    to check the fuel system which they said was ok but low compression they tell me it needs new camshafts if i replace the camshafts to sychronise them is it the same as cambelt timming the flat plates at the back of the cams to synchronise
    thanks Rob
  6. Re: 2.5tdi v6 AKE -01 camshaft problems
    1836 Post(s)
    What is the cars VIN?
  1. TFSi Camshaft problems - anyone heard of this?
    By garmcqui in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 13-03-2016, 06:50 PM
  2. Question regarding 2.5 tDi Camshaft problems
    By JGP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-02-2013, 10:57 AM
  3. 2.5tdi severe camshaft wear
    By shabazmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-12-2010, 01:04 PM
  4. A6 5cylinder 2.5tdi broken camshaft
    By drwint in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 21-10-2010, 08:23 AM
  5. Question Camshaft chain sprocket problems
    By happy2 in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2010, 02:26 PM
