Thread: Touran tdi dpf sensor nightmare
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Touran tdi dpf sensor nightmare
    #11
    May 2007
    17 Post(s)
    Quote Originally Posted by ryanp29 View Post
    could a blocked dpf be the cause......I thought that could mean a electrical issue
    The voltage test I suggested earlier only takes 5 mins or so and should give you a good clue about whether it's an electrical issue or a blockage. A short to power would make the ECU think the filter was blocked when it's not since the sensor output voltage is proportional to exhaust back pressure. If the wiring is shorted though, you wouldn't get 0.5V before the engine is started. The voltage would likely be higher than that. Having said that, a higher voltage key on/engine off "should" cause the ECU to log a sensor plausibility code which you don't have. But fault diagnosis is all about collecting clues about the fault and if I can collect another clue at the expense of 5mins work I think that's 5 mins well spent.
  2. Re: Touran tdi dpf sensor nightmare
    #12
    1840 Post(s)
    Did he recalibrate the sensor to the ECU?
  3. Re: Touran tdi dpf sensor nightmare
    #13
    May 2017
    Telford Shropshire
    No, after reading up on the forums I heard about this I think some call it adaptation? I ask him if he needs to do this whilst he was trying to fault find but he told me that he needs to get load readings first, do you think that could be the issue?
  4. Re: Touran tdi dpf sensor nightmare
    #14
    1840 Post(s)
    A new sensor must be calibrated.
  5. Touran tdi dpf sensor nightmare
    #15
    May 2017
    Telford Shropshire
    Hi I've carried out the voltage check and got the following results- yellow/ blue wire 5v, purple/ green wire 0.5 v, upon starting engine I got the same results apart from the signal wire increased to 0.6v when the engine speed was increased, so am I right in saying that the wiring is ok and the dpf is clear??
  6. Re: Touran tdi dpf sensor nightmare
    #16
    May 2017
    Telford Shropshire
    Hi all, just had it code read again and now the code is 01139 exhaust pressure sensor 1 (g450) signal to high p0473 short with power??? Any ideas guys??
  7. Re: Touran tdi dpf sensor nightmare
    #17
    1840 Post(s)
    You caused that by unplugging it with the ignition on, you can't do diagnostics with a multimeter unless you have a code reader to clear the codes afterwards, otherwise you chase your tail around in circles.
  8. Re: Touran tdi dpf sensor nightmare
    #18
    May 2017
    Telford Shropshire
    It went to the garage after I checked it all out with a multimeter to have the codes erased but it would not let him clear it!
  9. Re: Touran tdi dpf sensor nightmare
    #19
    1840 Post(s)
    If the sensor is new the wiring back to the ECU needs checking. Firstly, there is a fourteen pin connector near the battery where the G450 wires pass through
    G450 T14
    1. Yellow/blue at pin 11
    2. Grey at pin 4
    3. Lilac/green at pin 3
    Check at this plug for corrosion or damage first.
  1. Please Help VW Touran Diesel 2.0 DPF Nightmare ! Help needed !
    By BasementTapes in forum Touran - Sharan - Caravelle
    Last Post: 27-08-2014, 07:35 PM
  2. Touran 170 2.0 tdi Crank Position Sensor
    By Saxonbridge in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2013, 08:05 PM
  3. Touran map sensor location
    By porky 047 in forum Touran - Sharan - Caravelle
    Last Post: 14-05-2012, 11:24 AM
  4. Question Touran fsi NOx sensor
    By angus8 in forum Touran - Sharan - Caravelle
    Last Post: 16-07-2011, 08:15 PM
  5. Touran Brake Server Sensor
    By mully1999 in forum Touran - Sharan - Caravelle
    Last Post: 21-08-2009, 07:38 AM
