Thread: Golf mk5 1.9tdi PD130 turbo
  1. Golf mk5 1.9tdi PD130 turbo
    Apr 2016
    Durham
    My turbo is going on my golf mk5 1.9tdi pd105 and I'm wanting to put a pd130 turbo on it is this a simple swap or will I need to buy loads of stuff I know I will need to get it remapped but I'm not going to run stupid power probably between 140- 150 I'm assuming this will be fine with stock injectors thanks
  2. Re: Golf mk5 1.9tdi PD130 turbo
    1836 Post(s)
    There is some adaptation work to do on the pressure hoses as the attachment method is slightly different and the injectors my be close to their delivery limit..
  1. Question Will a pd130/pd150 clutch and flywheel fit my mk5 golf 1.9tdi
    By Golf TD in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2017, 10:02 PM
  2. 1.9TDi PD130 remap
    By bozie in forum Alhambra
    Last Post: 05-08-2016, 06:42 PM
  3. 1.9TDI PD130 Aux heater gurgling
    By matthewgdavies in forum Alhambra
    Last Post: 06-04-2012, 10:43 PM
  4. Please Help Low Power and Bad MPG - 1.9TDI PD130 AWX
    By iTDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2011, 03:27 PM
  5. A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    By General5*Hague in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2008, 06:01 PM
