Thread: VCDS help 2011 Polo
  1. VCDS help 2011 Polo
    Nov 2014
    Oxford
    Well had a guy contact me asking for some help with his polo. He has changed his headlamps for some aftermarket ones, led type. now his bulb warning indicator is on, and also his indicators flash quickly on the dash but outside work at a normal rate??? We spent quite a bit of time last night going through all we could find on the net, but still have not managed to sort out the problem. For the life of me I could not find anything in the long coding for this.
    Anyone else come across, and if so were you able to sort it out? Any help would be greatly appreciated
  2. Re: VCDS help 2011 Polo
    May 2007
    17 Post(s)
    An LED lamp will have a much higher resistance than a lamp with an incandescent bulb, so the BCM is seeing a circuit fault because the circuit resistance is much higher than the BCM is expecting it to be. He will probably need to add load resistors in parallel with the LED lamps to bring the circuit resistance back down to a level that the BCM is happy with.
  3. Re: VCDS help 2011 Polo
    Nov 2014
    Oxford
    Thanks for that. We were discussing the same thing that evening. Thought I would ask the question in case anyone has found a way around this
  1. Question Audi Q7 2011 VCDS programming help please
    By Shab2015 in forum VCDS - Help Requests
    Last Post: 10-07-2015, 03:03 PM
  2. Please Help 2011 Passat TDI Longlife service reset with VCDS - Adaptation error
    By master220 in forum VCDS - Help Requests
    Last Post: 02-02-2015, 07:54 PM
  3. 2011 CC VCDS autoscan anyone?
    By hartry in forum Passat CC
    Last Post: 03-12-2014, 03:45 PM
  4. 2011 1.2 tdi polo - no headlights
    By Mattvwpolo in forum Polo - Derby - Lupo - Fox
    Last Post: 05-12-2013, 07:45 PM
  5. polo bluemotion 2011
    By danielthesaint in forum Polo - Derby - Lupo - Fox
    Last Post: 01-06-2012, 06:07 PM
