Thread: Brake Pads
  1. Brake Pads
    Cheshire
    Time for some front pads on my A4. Code =1LT.
    Anyone replaced theirs? wondering which make to go for.... Pagid, Brembo, Bosch, ATE???
    Thanks!
  2. Re: Brake Pads
    Oct 2015
    GB
    I have allied Nippon on the back and Bosch on the front, guess what! The Bosch squeal!
  3. Re: Brake Pads
    Jun 2017
    Hereford, England
    Eurocarparts usually have some good deals on Brembo.
    If they squeal, take them out and put a bit of copper grease on the back of the pads.
  4. Re: Brake Pads
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Copper anti-seize paste should be used not grease.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Brake Pads
    Jul 2013
    Butron-On-Trent
    I've got 1LT brakes on the front of mine, just replaced pads and discs both ATE. Used a little 'Copperslip' or equivalent when I put them back together. Brakes fine and not a peep from them
  6. Re: Brake Pads
    Sep 2008
    6 Post(s)
    Quote Originally Posted by grant19841 View Post
    Slider bolts lubed?
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  7. Re: Brake Pads
    Jul 2013
    Butron-On-Trent
    No I didn't. I looked very carefully when I took them out and unless the lube they used is clear they were clean. Also I didn't want to risk the copper slip attacking the rubber in the plastic guides in the caliper. Maybe I've done the wrong thing but I figured discretion was the best option.
    No doubt someone on the forum may correct me
  1. Replies: 1
    Last Post: 31-12-2010, 08:47 AM
  2. 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    By unkleGsif in forum Bora - 1998 - 2005
    Last Post: 09-03-2010, 09:40 PM
