Thread: Overheats when I tow a caravan
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. Re: Overheats when I tow a caravan
    #21
    Dec 2013
    Hemel hempstead
    I am not sure when the crystals and pressure test check was carried out. I will ask. Someone earlier said about the thermostat. If that is faulty could that cause an over pressurised water system? Also if the head/gasket is faulty how would that cause water loss?
  2. Re: Overheats when I tow a caravan
    #22
    Dec 2014
    Bedford
    42 Post(s)
    Because it builds up too much pressure and forces the coolant through the head tank outlet via the cap relief.
  3. Re: Overheats when I tow a caravan
    #23
    Dec 2014
    Bedford
    42 Post(s)
    Very common problem on high mileage 1.9pd engines and early pds and more common on the 115bhp engines.
  4. Re: Overheats when I tow a caravan
    #24
    Pembrokeshire
    22 Post(s)
    just done a gasket on a 100 bhp passat, same thing, fine until you clog it up a hill, then it gets hot and starts to blow. that had a certain blow mark on the gasket which more or less rules out a porous head..
    0 2 0
  5. Re: Overheats when I tow a caravan
    #25
    Dec 2014
    Bedford
    42 Post(s)
    A lot of people use 150bhp head bolts as well on the gasket replacement.
    0 2 0
  6. Re: Overheats when I tow a caravan
    #26
    Pembrokeshire
    22 Post(s)
    didnt know there was a difference
  7. Re: Overheats when I tow a caravan
    #27
    Dec 2014
    Bedford
    42 Post(s)
    Higher tensisity ....if thats spelt right. Also engine modders/builders/mappers etc. Use them especially on the 115bhp.
    0 2 0
  8. Re: Overheats when I tow a caravan
    #28
    Dec 2013
    Hemel hempstead
    I have authorised the dealer to strip down the head to look for a head gasket problem. I am hoping for a clear sign of a blow!!
    0 2 0
  9. Re: Overheats when I tow a caravan
    #29
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Ok, keep us posted, hopefully that warranty covers it.
  10. Re: Overheats when I tow a caravan
    #30
    Dec 2013
    Hemel hempstead
    The sharan has been with VW dealer since 17 May being stripped down and having its head sent off for testing. Final diagnosis is a blown head gasket and slightly distorted cylinder head. Fortunately all covered by my warranty. Thanks to all for your advice.
  1. A3 1.8T 2003 Overheats when driving over 2000rpm, then loss of power
    By rustopha in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-01-2017, 05:15 AM
  2. 1.8T, my car overheats when turbo kicks in
    By lukescotty in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-01-2012, 03:20 PM
  3. Question Caravan towing
    By Golf tdi Hal in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2011, 08:30 PM
  4. Tiguan has gained power but overheats
    By superstardeejay in forum Tiguan
    Last Post: 19-02-2011, 07:13 PM
  5. Golf mk 4 overheats
    By bobdrivervw in forum VCDS - General Questions
    Last Post: 31-05-2008, 11:21 AM
