Thread: Overheats when I tow a caravan
Results 11 to 20 of 31
  1. Re: Overheats when I tow a caravan
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by purple_penguien View Post
    Did an 85 mile drive on the motorway yesterday without the caravan and the STOP light came on. Needed 1.5 litres of water. Have booked it into the VW dealer again for another look. Will let you know what they say. Thanks for you advice
    I would take it elsewhere. Dealers have little interest in cars over 5 years old.
    Ian
    A4 B6 Avant Nogaro Blue
    0 2 0
  2. Re: Overheats when I tow a caravan
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If that's the case then the problem has developed from only happening when towing, and the dealer should be able to replicate the fault on a test drive and see where you stand with this warranty. Good luck.
  3. Re: Overheats when I tow a caravan
    Sep 2008
    chester
    17 Post(s)
    Have you got another pressure cap try from a donor car
  4. Re: Overheats when I tow a caravan
    Dec 2013
    Hemel hempstead
    No I don't. Do you think that could be a cause?
  5. Re: Overheats when I tow a caravan
    Jul 2015
    Staffs
    46 Post(s)
    A faulty one can cause pressure problems. Mostly coolant filling the expansion tank
    Ian
  6. Re: Overheats when I tow a caravan
    Sep 2008
    chester
    17 Post(s)
    If the pressure is not right it will boil at a lower temperature than if it is higher,long shot but could be worth a try.
  7. Re: Overheats when I tow a caravan
    #17
    Dec 2013
    Hemel hempstead
    Took the sharan back to the VW dealer who drove it around and witnessed overheating and the STOP sign coming on. Said they noticed high pressure in the water system and did a crystals test to check for carbon monoxide in the water system but negative result. Also did a pressure test but again negative result so no definitive evidence of a head gasket problem. They recommend I pay them to take the cylinder head off to check for a head gasket (£750 plus parts) but with a negative crystals and pressure test result seems an expensive gamble that the head gasket is actually the problem. Problem is they will charge a £120 investigation fee unless I go ahead with the £750 engine strip down. . Then if it is the head gasket that would be covered by my warrantee. If not then I am £800 ish out of pocket and no further forward.
  8. Re: Overheats when I tow a caravan
    #18
    Dec 2014
    Bedford
    42 Post(s)
    How does your Sharan run from cold? Is it very flat from cold in the winter months?. Have you had the turbo diaphragm actuator tested. I wonder if it is split and so it's in the full boost default causing excessive cylinder pressure which in turn is causing cylinder head lift... Just a thought.
  9. Re: Overheats when I tow a caravan
    #19
    Dec 2013
    Hemel hempstead
    Haven't noticed any lack of power at all
  10. Re: Overheats when I tow a caravan
    #20
    Nov 2010
    104 Post(s)
    Sounds like you are tied to the dealer by this warranty. To me , the problem with the engine seems like a head gasket or cracked head, that only opens up while driving, that gasket fault or head crack has developed from only showing when pushing the engine hard (towing) to happening while regular driving. The cooling system is gassing up causing gas pockets around the system, loss of circulation and coolant, when they pressure test it, it has cooled down enough to close the crack. When did they do the crystal test? In the workshop after the engine had cooled a bit or at the roadside after a good ragging while it was still red hot and losing coolant? Is the cylinder head covered by the warranty or just the gasket?
  1. A3 1.8T 2003 Overheats when driving over 2000rpm, then loss of power
    By rustopha in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-01-2017, 05:15 AM
  2. 1.8T, my car overheats when turbo kicks in
    By lukescotty in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-01-2012, 03:20 PM
  3. Question Caravan towing
    By Golf tdi Hal in forum Golf MK3 - 1993 - 1999
    Last Post: 11-03-2011, 08:30 PM
  4. Tiguan has gained power but overheats
    By superstardeejay in forum Tiguan
    Last Post: 19-02-2011, 07:13 PM
  5. Golf mk 4 overheats
    By bobdrivervw in forum VCDS - General Questions
    Last Post: 31-05-2008, 11:21 AM
