Thread: Coolant running fast out of cylinder block.
  1. [SOLVED] Coolant running fast out of cylinder block.
    Nov 2015
    Paignton, Devon
    I have a lot of water/coolant pouring out of cylinder block right behind the timing case. Originally thought it was coming out the bottom. I have filmed it and it's definitely coming straight out no doubt about it from behind the timing case.
    I cannot see any any joint or gasket though so what exactly has broken and how do I get to it.
    I used Radweld not too long ago for another little leak elsewhere and that worked. So when this happened the first thing I did was buy Kseal but it doesn't seem to have touched it. £11 literally down the drain!
    I pour the water into coolant now and within seconds it's coming out of this whole.
    Any help?
    Golf MK3 1995 ABD engine
  2. Re: Coolant running fast out of cylinder block.
    Nov 2015
    Paignton, Devon
    Quote Originally Posted by Nuggit View Post
    Any help?
    Vid 1
    Water leak pt1. - YouTube
    Slightly better Vid 2
    Water Leak pt2. - YouTube
    Please help!
  3. Re: Coolant running fast out of cylinder block.
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    sorry - tea time at work and no access to you tube! is it not the water pump to engine block connection?
  4. Re: Coolant running fast out of cylinder block.
    Nov 2015
    Paignton, Devon
    All fixed. Basically there is a closed off would-be hole behind the timing case, it's gained a little hole that was pouring out any water/coolant from it which you can see on YouTube.
    I could not remove the cam sprocket so had to drill a 20mm hole through the plastic case to find the leak. Then I used some Granville sealant stuff oil and water resistant up to 250 degree. So should be fine.
    I made the process a lot longer and stressful by turning the cam after removing the belt. .. but this enabled me to learn the TDC process and all is now well.
    Loooooong learning curve. I have pictures of it all - anyone know the best place to share my little guide?
    Cheers, Lee.
    EDIT: it was a leaky Core Plug.
  1. Question S4 V8 Alloy cylinder block, worn cylinder bores?
    By Burfy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-05-2012, 01:27 PM
  2. Question audi A4 2.5 tdi sport auto cabrio running to fast
    By gtautos in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2011, 09:16 AM
  3. cylinder block heater - retrofit possible??
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-03-2011, 03:03 PM
  4. A6 Cracked Cylinder Block
    By Adrianh in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-06-2008, 11:45 AM
  5. A6 2.8 V6 head gasket gone or cylinder block cracked!!! What are my options?
    By helium4amc in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 16-07-2007, 07:49 PM
