Thread: A6 Allroad Steering locked and non starting
Results 11 to 20 of 22
  1. Re: A6 Allroad Steering locked and non starting
    #11
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    Quote Originally Posted by smaugc6 View Post
    Scan the car you should get a steering column lock actuator fault, if you reset it the car will start again.
    You'll need press brake hazard and high beam and then you can get access to the vehicle diagnostics without ignition.
    I have done that and cleared codes, basic options was not highlighted so did not have ability to reset, do I have to enter a security code to get access and if so what is it? Because none of the ignition lights come on I wonder if there is a different issue. Been through all fuses, all OK.
    Yes (DUH!) Battery is good, nearly new, nonetheless I charged it all night, problem persists.
  2. Re: A6 Allroad Steering locked and non starting
    #12
    May 2015
    United Kingdom
    6 Post(s)
    Was there a code in the start authorisation module for steering column lock actuator
  3. Re: A6 Allroad Steering locked and non starting
    #13
    May 2015
    United Kingdom
    6 Post(s)
    06 Audi A6 ignition problem solved - YouTube
    Have a look at this video this should explain it, because yours is a manual I think the key doesn't get stuck.
  4. Re: A6 Allroad Steering locked and non starting
    #14
    Aug 2007
    You are rather ahead of me here, the computer is just borrowed, I don't really know what I am doing. I looked in 15 Steering, found and deleted codes (the date and time on those codes was some hours after the initial problem arose) but the options button where I had hoped to find the reset option was not available. Where is the start authorisation module?
  5. Re: A6 Allroad Steering locked and non starting
    #15
    May 2015
    United Kingdom
    6 Post(s)
    I think it's module 5 the acc/start auth module that you need to scan and there should be a fault for a steering column lock actuator.
  6. Re: A6 Allroad Steering locked and non starting
    #16
    Aug 2007
    Yes there are faults relating to that in Add 05 acc/start, add 08 hvac, add 09 cent elec and add 19 can gateway. Laptop battery flat have to wsit a while. So there should hopefully be a reset option in the 05 acc/start area.
  7. Re: A6 Allroad Steering locked and non starting
    #17
    May 2015
    United Kingdom
    6 Post(s)
    Perfect just reset the codes and it should start again, keep posted if it does.
  8. Re: A6 Allroad Steering locked and non starting
    #18
    Aug 2007
    Sorted, Massive thanks smaugc6, would not have done it without you, WONDERFUL!!!!!!
  9. Re: A6 Allroad Steering locked and non starting
    #19
    Nov 2012
    Somerset UK
    I love it when a plan comes together!
  10. Re: A6 Allroad Steering locked and non starting
    #20
    Jul 2008
    Quote Originally Posted by mhobson View Post
    Does anyone know if this works in vcds-lite? Or does it need full blown vcds?
  1. Allroad 2.5Tdi poor starting
    By Rocheydub in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2015, 01:27 PM
  2. Question A4 Allroad 2014 steering improvement
    By GusAllroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-04-2015, 12:50 PM
  3. Allroad 2.5 TDI not starting
    By Tony Parker in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-07-2014, 08:29 PM
  4. Please Help ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2013, 11:00 PM
  5. Steering wheel locked - Help!
    By Desperatedad in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-06-2009, 01:41 PM
