Thread: rear wiper
Results 1 to 10 of 14
  1. rear wiper
    May 2014
    bradford, west yorkshire
    hi,
    since i bought my car the rear wiper as not worked, today swapped the motor for one that i had on my other car which was working but once on the A3 it doesnt work the washer works fine and i can hear the relay click when i switch it on, i have checked the wires in the left hand boot hinge and they seem to be ok is there something else it can be
  2. Re: rear wiper
    May 2007
    17 Post(s)
    Does the boot light work properly?
  3. Re: rear wiper
    May 2014
    yes the boot light is fine or should i say it comes on when the boot is open, whether or not it goes off im not sure
  4. Re: rear wiper
    May 2007
    17 Post(s)
    Remove the parcel shelf and make sure it switches off when the tailgate is closed. The rear wiper usually doesn't work when the tailgate is open. It's the boot light switch that tells the BCM whether the tailgate is open or not.
  5. Re: rear wiper
    May 2014
    just got home from working away and found the boot light not working no longer, i check and changed the bulb opened and shut the boot a few times and still nothing but the washer still works
  6. Re: rear wiper
    May 2007
    17 Post(s)
    Assuming the wiring between the body and the tailgate is OK, I'd be taking a look at the connector on the tailgate latch next. The switch that tells the BCM that the tailgate is open is inside the latch.
  7. Re: rear wiper
    May 2014
    which side of the body does the wire for the boot latch run from, and is there a way to get the rubber gaiter completely out of the way without cutting it off to check the wiring
  8. Re: rear wiper
    May 2007
    17 Post(s)
    Quote Originally Posted by juleshs1968 View Post
    I've never had to fix an A3 but on the Golf the wiring routes through the N/S gaiter.
    Don't cut the gaiter. Just remove it at one end and push it back down the harness. It's a bit of a PITA but you'll manage. Just be aware that all the wires in the gaiter are white. Well, I think the earth wire is brown but all the others are white...just to make it interesting.
    Good Luck!
  9. Re: rear wiper
    May 2014
    i have checked the wiring and it is all ok, i have notice that the boot light doesnt always come on and also doesnt show up on the dash as being open will these be related
  10. Re: rear wiper
    May 2014
    still no rear wiper, new lock latch, new wiper motor, checked wires in rubber gaiter they seem ok i can hear the relay click when i switch it on, rear washer still works and still the boot light is intermittant and it doesnt show up on the dash that the boot is open, is there something i am missing?
    just tried something else, the connector to the boot light and the one to the boot lock micro switch are the same so i plugged the light into the micro switch connector and absolutely nothing happened.
    Anyone got any ideas?
  1. Rear Wiper
    By mjom89 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 10-12-2015, 08:24 PM
  2. Replies: 3
    Last Post: 09-01-2013, 01:14 AM
  3. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    By Ray P in forum Polo - Derby - Lupo - Fox
    Last Post: 14-12-2009, 10:15 AM
  4. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    Last Post: 14-12-2009, 12:01 AM
  5. '97 A3 rear tailgate and rear wiper
    By steveoh in forum Audi A3 - Archive Topics
    Last Post: 07-03-2008, 11:25 PM
