Thread: Air Con not working
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. Re: Air Con not working
    #21
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Do you have any gas in the system? Re - reading these posts I can't see anywhere that you got it regassed after the pulley was fitted. If it's empty then you'll keep getting 00256 no matter how many sensors you try.
    Quote Originally Posted by Bubbauk View Post
    I have tried another sensor now which is the exact same from another known working car and I am still getting
    00256 - Sensor for refrigerant pressure/temperature Lower limit not reached
    Should I try taking it to get re gassed again in case it didn't work properly the first time?
  2. Re: Air Con not working
    #22
    Mar 2009
    Montenegro
    13 Post(s)
    Check your fan, if it is not working or if it cannot work at high speed then can cause A/C malfunction.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  1. Attention Audi a3 2009 sound system failure/bass not working/speakers not working
    By Simba2004 in forum In Car Entertainment
    Last Post: 02-11-2015, 11:41 AM
  2. Important Rev counter not working, speedo not working, new clocks needed?!
    By Simba2004 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-05-2015, 02:18 PM
  3. Question USB Flash drive Was working fine, Now Not working anymore!
    By Rajsta in forum In Car Entertainment
    Last Post: 19-03-2015, 09:16 PM
  4. Cigarette lighter not working - Engine & Oil temp gauges not working.
    By Shagger7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 12:10 PM
  5. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
