Thread: Air Con not working
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Air Con not working
    Nov 2016
    Carrickfergus
    Hi Everyone, I have a 2005 A6 C6 2.0 TDI and the car will not come out of economy mode, I left it into a local place to be regassed and when they gassed it they said it still did not work and could not be repaired so they took all of the gas out again. When I got the car back and read the codes I got the following fault
    Trouble codes:
    00256 - Sensor for refrigerant pressure/temperature Lower limit not reached
    static
    Frequency counter: 1
    Measurements:
    1.3 °v.OT
    Mileage: 119249 km
    Driving cycle: 103
    Date: 2017-04-25 19:58:38
    Priority: 3
    01854 - Right front heated seat Open circuit
    Intermittent
    This was not there before I left it into them which I found odd, after looking online lots of people reported this sensor being faulty so I ordered one up and replaced it but it looked slightly different although seemed to fit OK but the fault is still there, does anyone have any ideas what to look at next, does the car just need regassed again? I dont want to have to pay for this if there is still something faulty.
    Regards
    David
  2. Re: Air Con not working
    Jul 2012
    Kent
    the A/C place is fishing for extra work there... as long as the circuit held vacuum and they put in the correct charge amount + oil, you could then fix the system yourself by simply changing the sensor bud.
    Why did they remove the gas if it wasn't leaking ?
    Did they charge you for this also ? I hope not, as it's now back in their machine.
    I'd hazard a guess that you just need a new pressure switch.
    You'll never get the A/C system to run now, as you've got no gas in it...
    Get them to regas correctly, then you can fault find thereafter.
    HTH.
    2007 3.0 tdi S-Line Avant.
    20 inch RS alloys, F/r park distance,S-Line leather, colour coded All road side skirts, Xenons
    Luv it !
  3. Re: Air Con not working
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I agrree with Tazman, sensor is a very common fault on A6 ( both A6`s Ive had have failed!). I guess your system wasnt even low and now theyve left you with no gas!
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: Air Con not working
    Nov 2016
    Carrickfergus
    Hi, thanks for the replies, I have replaced the sensor already but the error is still there, I am not sure if it now just needs re gassed to clear the error or not. The garage did not charge me and told me it was not worth repairing and to just live without it, it was only a small garage so I am not sure how much i should trust that.
  5. Re: Air Con not working
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That garage has left you in a worse position than when you originally drove in. No explanation as to why it is not worth repairing ? I think you have to decide if a certain system in your car is not worth repairing rather than them ! The error will never clear while there is no gas in the system.
    If you want it sorting, take it somewhere that knows what they're doing with air con, go through the vac test, regas, then see what is required next, might just be that sensor. My passat air con wasn't working as the compressor drive pulley rubber had sheared, 30 quid replacement from a scrapper sorted it. Yours may be beyond economical repair but you need a bit more info to make that call.
  6. Re: Air Con not working
    Sep 2008
    chester
    17 Post(s)
    As above, no pressure in the system,you wont be able to clear the fault code.
  7. Re: Air Con not working
    Jul 2013
    76 Post(s)
    Take the car back to the garage and get them to refill the system.
    They should do this for free.
    If you had a leak then they should have told you.
    Dan
    2009/2010 2.0 TDIe SE
  8. Re: Air Con not working
    Nov 2012
    Somerset UK
    Certainly worthwhile shopping around as i had both of my cars regassed on a groupon offer for £20 inc for each!
    In both they gave me a printout of the amount taken out and the refill amount of both gas and oil.
    They even did an antibac treatment at no extra charge and said they would honour that price for as long as I owned the cars
    Just saying as some aircon places charge £50 as a 'special' £75 if a cleanse is included, so there is quite some profit margin.
  9. Re: Air Con not working
    Nov 2016
    Carrickfergus
    Hi Everyone, thanks for all of the replies, I took it to another garage today and got them to gas it, they pressure tested it and gassed it and now the econ light is going off and staying off and the fault code has disappeared but still no cold air, does anyone have any ideas what to look at next, how can I check if the compressor is working?
    David
  10. Re: Air Con not working
    Sep 2008
    chester
    17 Post(s)
    Quote Originally Posted by Bubbauk View Post
    David
    I would check the front of the compressor to see if the clutch has fell off or loose,if the compressor is working you should be able to hear it hissing if follow the high pressure pipe up to the big union nut.
  1. Attention Audi a3 2009 sound system failure/bass not working/speakers not working
    By Simba2004 in forum In Car Entertainment
    Last Post: 02-11-2015, 11:41 AM
  2. Important Rev counter not working, speedo not working, new clocks needed?!
    By Simba2004 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-05-2015, 02:18 PM
  3. Question USB Flash drive Was working fine, Now Not working anymore!
    By Rajsta in forum In Car Entertainment
    Last Post: 19-03-2015, 09:16 PM
  4. Cigarette lighter not working - Engine & Oil temp gauges not working.
    By Shagger7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 12:10 PM
  5. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
