DIY Oil and filter change –
28-04-2017,01:00 PM
I decided to do a DIY interim oil and filter change on the 2.0Tdi today.
I am using a vac pump to draw the oil out through the dip stick port.
1. Cracked the filter and removed it from can to allow majority of oil to drain through to the sump.
2. Inserted the vac tube into the dip stick port as far as it will go, which when checked is the same depth as the dip stick, but only got 1 litre of oil out.
I cannot imagine there has only been 1 litre of oil in the engine as there have been no warning, the dip stick shows oil and oil temp has been 87/90C.
What am I missing.
2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
