Thread: Reverse light and fog light not working
  1. Reverse light and fog light not working
    Mar 2017
    Ipswich
    I have a 2006 golf 1.9tdi . The notification on the dash has reverse light and rear fog defective.
    I have checked the wiring all thru especially thru the boot and all is fine. Therereverse switch on the gearbox hs been tested and is also fine. All fuses are intact .
    There is no voltage present at either lamp holder when they are meant to be live.
    Any help ??
  2. Re: Reverse light and fog light not working
    May 2007
    17 Post(s)
    So you've checked continuity of the wiring between the power supply control unit/BCM and the lamps and it's all good?
    BTW, there shouldn't be voltage at the lamp holders while there's a bulb failure warning notification shown on the dash....that's normal.
  1. Reverse light not working
    By Dokiboss in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2014, 03:18 AM
  2. Please Help Reverse light not working
    By Rob_2i in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2014, 08:37 PM
  3. Reverse and brake light not working
    By jalz in forum Ibiza - Cordoba
    Last Post: 09-06-2014, 10:50 PM
  4. Reverse light backup lights not working
    By jamie pockets in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-02-2012, 04:53 PM
  5. Question ESP warning light and Reverse Light Not Working!!! - Please Help
    By Rodders80 in forum Golf Plus
    Last Post: 25-09-2011, 09:20 AM
