Thread: No power when accelerating, struggling to get to 60 mph
  1. No power when accelerating, struggling to get to 60 mph
    Apr 2017
    Portsmouth
    Hi guys
    So I made the mistake of thinking that after all the trouble I have had with Fiats I could easy buy a 1.2 polo to work
    on and get back onto the road... clearly not a smart move.
    I bought a polo that displayed signs of a burnet out valve. engine shake ect. I took the head off to work on it and to find the valves were still
    good. I cleaned up the head put it back changed the chain as theold one had jumped a tooth as well. so I thought the problem was solved.
    but still I have the acceleration issue. when you put your foot down in second It hardly moves and it struggles up hills.
    Looking for any help as what it could be.
    car is a 1.2 BMD 55 e 2007
    I changed the spark plugs and the coils but alas it still bogs down and wont pull. any help would be appreciated
    also to add no EML
  2. Re: No power when accelerating, struggling to get to 60 mph
    1836 Post(s)
    Start with a code read, print out, code clear, re-run and another code read/print and post the results. Did you check the axial play in the exhaust valve guides? These are extremely prone to wear.
  3. Re: No power when accelerating, struggling to get to 60 mph
    Apr 2017
    Portsmouth
    Hi Crasher thanks for the advice!
    Sorry I have my dissertation due in so I had been a bit busy so I left the car for a while. I came back to it and started again from basics
    I checked fuel spark and then looked at the exhaust. After going through it I came to the conclusion my Catalytic converter was blocked.
    Found one at a local Factors and plumbed it in now the car is up and running, It was an interesting little project and got to learn a lot about
    the 3 pots. in the end I just had a hate for the car and gave it to my girlfriend .
    Thank you also for your answers in other posts, I have been following your very useful advice that led me to finally being able to fix the issue.
    Takunda
  1. Loss of Power - Accelerating
    By Boat_face in forum Golf MK4 - 1999 - 2004
    Last Post: 11-04-2013, 12:13 PM
  2. No power when accelerating with multitronic help...
    By basspower in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2010, 04:55 PM
  3. Please Help Struggling no power
    By salt258 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-09-2009, 10:47 AM
  4. Question blip in power when accelerating
    By a4audio in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-08-2008, 01:43 PM
  5. loss of power in 4th & 5th - struggling to reach 120kph
    By niahgoe in forum Golf MK3 - 1993 - 1999
    Last Post: 02-01-2008, 04:22 PM
