Thread: No Power to HVAC? - 30A fuse is good
  1. No Power to HVAC? - 30A fuse is good
    2003 Audi 1.9 TDI
    Hi, whilst testing the power supply to the Aircon compressor (N280 valve?), I accidentally shorted out the power supply to the compressor and now the HVAC system is dead, including the fan. I expected the main aircon fuse to have blown but its still good (its the 30A fuse listed as number 25) , is there another fuse I should be checking or perhaps a relay?
    Thanks for any advice as I'm getting nowhere fast! Originally I was checking for a suspect compressor as pressure is good and aircon fan came on but the compressor didn't seem to be kicking in (note the car had not been used for a couple of months).
    Any help much appreciated.
  2. Re: No Power to HVAC? - 30A fuse is good
    Sorted, found a 10A KI 15 supply (control unit) fuse that had blown. Had to clear a load of fault codes but looks good - still have the aircon problem of compressor not compressing - but I'll post a new thread for that.
  3. Re: No Power to HVAC? - 30A fuse is good
    Apr 2017
    Hi where was the fuse located?
  1. Fusebox power supply fuse?
    By Chawkster in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2014, 07:26 PM
  2. Question Power draining overnight through fuse 4
    By galva in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-10-2012, 09:27 AM
  3. Please Help Alhambra no power fuse 19 pos CAN BUS issue
    By Dozz in forum Alhambra
    Last Post: 02-07-2010, 09:11 PM
  4. Fuse for rear 12v power outlet???
    By jabba2020 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2007, 07:06 PM
  5. Lack of Power (Blown Fuse!!)
    By TJCorsa in forum Bora - 1998 - 2005
    Last Post: 23-11-2005, 11:19 PM
