Thread: Head gasket or not...
Results 1 to 10 of 14
  1. Head gasket or not...
    Mar 2012
    Belfast
    Guys,
    Was just on a call to a mechanic and he told me it could be head gasket failure. It freaked me out because I had to scrap my last car just for exactly same reason (except the symptoms and the car make were different...).
    I then rang another mechanic and he told me he doubts it is head gasket and said it could be water pump or thermostat etc...
    I'm seriously freaking out though coz the the first guy I rang is a very good VGA mechanic and I would trust him 100%.
    So here's what's going on:
    CAR
    Volkswagen Passat, 1.9, 2008, 75k miles.
    TEMPERATURE:
    The car takes a few minutes to warm up then goes to 90C and... drops a bit - not much (goes down to 85-87, then back to 90, depending on the driving... then sometimes down to 80 - but very rarely). Sometimes it stays right on 90C for longer.
    It NEVER goes over 90C.
    HEATING
    I usually keep it on 22C and it takes a few minutes to start blowing warm air but then after some time it the air temperature/ and fan intensity drops and it is not as warm as you would expect.
    So in essence (I usually drive it on motorway) the temp fluctuates and the fan is not warm enough.
    Some additional info:
    COOLANT
    Keeps the level fine (it doesn't look like it has dropped level at all), it's clear, doesn't smell of diesel.
    OIL CAP
    Looks perfectly fine, no milky stuff around it.
    OIL DIP STICK
    Looks the right color... again no milky stuff anywhere.
    PERFORMANCE
    The car starts, and drives like new.
    Whats your thoughts?
    Thank you in advance.
  2. Re: Head gasket or not...
    Pembrokeshire
    22 Post(s)
    fisrt thought is a water pump impellor broken, a common problem. does the coolant system pressurise after a drive and does it still have pressure when its all cooled down, ie. release the cap and get pressure blowing out ? if yes, then its a head gasket. head gasket faults are sometimes difficult to pinpoint though..
  3. Re: Head gasket or not...
    Mar 2012
    Belfast
    Zollaf, no, haven't noticed any pressure whatsoever in the coolant system after it has cooled down. (This was happening in my other car and yea it was head gasket there).
    I just can't understand why that mechanic's first guess was head gasket.... it really freaked me out.
  4. Re: Head gasket or not...
    Pembrokeshire
    22 Post(s)
    we have all come to a conclusion that the head gasket is duff, then found its not.. simple test though, on tickover, do you get a good constant flow of coolant back to the header tank through the small pipe that goes into the top of it ?
  5. Re: Head gasket or not...
    Mar 2012
    Belfast
    Zollaf.. could you elaborate please? I'm a bit slow when it comes to cars...
    You want me to drive it then stop, turn the engine off and see if the tank is refilled with the coolant right away?
  6. Re: Head gasket or not...
    Pembrokeshire
    22 Post(s)
    no, the level in the tank shouldnt change.
    no, thisn is what you do,. start engine, open bonnet, observe small pipe going into header tank. there should be a constant flow of coolant all the time the engine is running.. you can see it if the tank is clean, if not remove the pipe and see if coolant flows.. should increse if you rev the engine. if there is no flow, the pump is suspect.
    0 2 0
  7. Re: Head gasket or not...
    Mar 2012
    Belfast
    Will try that... so if there's no flow then water pump, which is awesome news (anything but head gasket is awesome news to me)... what if there's flow though?
  8. Re: Head gasket or not...
    Pembrokeshire
    22 Post(s)
    if there is flow, then the pump is probably ok. the impellr is plstic (probably) and they slip on the shaft, some flow can mean the pump is duff though... but if you rev it and it gets no stronger then its likely slipping.
    0 2 0
  9. Re: Head gasket or not...
    Mar 2012
    Belfast
    Zollaf, thanks mate. Will check it.... then the mechanic is booked for next Tuesday. I will let you know... thanks again mate. I so hope its not the friggin head gasket so I don't lose another car again.
    0 2 0
  10. Re: Head gasket or not...
    Sep 2008
    SE London
    Change thermostat for new from dealer spares -- not an aftermarket item
    Use the second mechanic.
    What colour is your coolant?
    Remove coolant reservoir cap. Run engine until up to full working temperature.
    Do you see coolant being pumped back into the reservoir? Simple water pump check.
    While there "burp" your system -- place heater on full and leave running for 10 mins
    with occasional blip on throttle. Prepare to increase coolant level to bottom mark
    on reservoir if necessary
    When was cambelt last changed? Water pump should've been changed with it.
    If there's hardly any flow back get your water pump changed too with an exchange
    item, again from dealer spares -- don't use aftermarket -- there's credit to be had
    on your old one when returned
    Good advice from Zollaf BTW...
    Last edited by RichardSEL; 25-04-2017 at 06:27 PM. Reason: now I've actually read all of the thread !
    1 2 0
  1. Replies: 19
    Last Post: 26-01-2017, 09:39 AM
  2. Arl poor mpg after head new cam/head gasket
    By M53494 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-12-2015, 11:16 AM
  3. 3.0 V6 head gasket
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2013, 07:57 PM
  4. What to use on a new head gasket gasket and other joints?
    By manc in forum Golf MK5 - 2004 - 2009
    Last Post: 20-08-2011, 12:05 PM
  5. Do you have to run in a new Head Gasket?
    By jsbarcs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-12-2008, 09:21 AM
