Thread: Abs sensor fault
  1. Abs sensor fault
    Nov 2016
    Sarajevo,Bosnia and Herzegovina
    Hello!
    I've got light on dash and vag com said that is rear right abs sensor faulty. It's 2001 2.5 tdi quattro 132kw AKE. Audi said about 170€ for oem bosch sensor which is too expensive for me. Oem part no. 4B0 927 807 J. I find used abs sensor with part no. 4B0 927 807 Q also from 132kw quattro rear right side.
    So,difference is in that last letter and I'm asking if someone know will it fit on my A6?
  2. Re: Abs sensor fault
    Nov 2016
    Swindon
    13 Post(s)
    Quote Originally Posted by Sale_S_line View Post
    Hello!
    ******* Search 4b0 927 807 j
    The Bosch part is expensive, maybe you can try another brand.
  1. Cmp sensor engine speed sensor fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2022, 10:44 PM
  2. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  3. Please Help DPF pressure Sensor fault & Xenon Range Fault
    By jkuk1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-11-2013, 03:17 PM
  4. Question Bora - Engine judder when driving - MAF sensor, temp. sensor or ABS fault??
    By Christo3000 in forum Bora - 1998 - 2005
    Last Post: 20-06-2011, 05:29 PM
