Thread: 6n2 drivers door will not open
Results 1 to 9 of 9
  1. 6n2 drivers door will not open
    Jul 2009
    Havant, England
    Hi guys, I've not posted here for a while as have been well busy away from cars.
    My wifes 4 door 6n2 unlocks and locks via central locking on both front doors, as the knobs go up with a turn of the key, as normal. However, the drivers door will not open from the inside or the outside.
    I have resorted to cutting a segment of door card away to operate mechanisms by hand inside the door, but something isn't letting go as it still wont open.
    I've even had the wife pulling on door handle while I lay along seats and kick the door, still to no avail.
    Any further suggestions would be appreciated before I cut the door off.
  2. Re: 6n2 drivers door will not open
    Jul 2009
    Havant, England
    It's further compounded by the wife being disabled, if she's having a bad day and needs to do the school run, sliding across is not really manageable.
  3. Re: 6n2 drivers door will not open
    Aug 2016
    Stoke
    6 Post(s)
    No idea if you've sorted this now, but your bowden cable is clearly at the wrong tension.
    If you slam the handle hard (and i know this will feel horrific) using like your elbow or fist. It'll reseat and the door will open, only for it to happen again next time you close it. I would hazard a guess that the bowden cable is either too tense or too loose.
  4. Re: 6n2 drivers door will not open
    Jul 2009
    Havant, England
    Thanks for answering Skezza. That is what Youtube et al suggested. However, the 6n2 door handle is old skool hard connected, there is no cable, the door handles interior simply hooks over the lever that is supposed to release the catch.
    Unfortunately, it's still like it.
  5. Re: 6n2 drivers door will not open
    Dec 2014
    Bedford
    42 Post(s)
    Drill the barrel out. Now you will have a nice big hole in the handle. Get a torch have a look in the hole. You should see a slotted plastic section. This is where the the barrel paddle operates the the lock mechanism. Now get a nice long strong flathead screwdriver. Put it in the hole and smack it several times with a hammer. Door will open up when the deadlock spring has released. Now you need a handle with barrel and a key and a door lock mechanism. Remember to check the wiring during the replacement process.
  6. Re: 6n2 drivers door will not open
    Jul 2009
    Havant, England
    Cheers FLAPPERKACK76. Might this still be the issue even though the knob has come up? If so, I've got no choice but to give it a go. Sure beats cutting the door off.
  7. Re: 6n2 drivers door will not open
    Dec 2014
    Bedford
    42 Post(s)
    Only one way to find out... as you say next plan is an angle grinder.
  8. Re: 6n2 drivers door will not open
    Jul 2009
    Havant, England
    Indeed. Will get on the case as soon as and report back here with results. Might help others in the future.
  9. Re: 6n2 drivers door will not open
    Jul 2009
    Havant, England
    Hey guys
    I got the door open. It is fiddly but I used one of those cheap Torx bits and a 1/4" ring spanner to undo the bolt holding the door handle on. You have to have the rear passenger door open and it's a fiddly job but it works. Once I got the handle free via a flat screw driver and bit of jiggling, I then pulled the catch just behind the door skin and the door opened. I repeated it by locking and unlocking the car via the passenger door and tried again. So I deemed the door handle to be the culprit.
    Closer inspection of the door handle revealed the thin cast flanges on the locking paddle to be broken, also the castellated bit at the bottom and from what can gather from further pictures, there's a third component, and that isn't even there. So I reckon once they're all present and correct, the wife will no longer have to climb through her car to drive it. Job's as good as done in my book. Hurrah.
  1. Please Help drivers door open
    By siblo in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 29-12-2015, 09:40 PM
  2. Drivers door will not open with key fob
    By shuts1000 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-07-2014, 03:52 PM
  3. Please Help Drivers door won't open
    By nebrog23 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2008, 02:21 PM
  4. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  5. Why won't my drivers door open?
    By carlyd28 in forum Golf MK2 - 1984 - 1992
    Last Post: 02-02-2008, 08:57 PM
