Thread: Air con G395 sensor no vaultage help please
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: Air con G395 sensor no vaultage help please
    #21
    May 2008
    26 Post(s)
    Ok thanks, will give it a go. Did you reuse the o ring off the old sensor or is a new one a better idea? I guess the O ring sits right down right at the end of the threaded part? (My new sensor came without O ring)
  2. Re: Air con G395 sensor no vaultage help please
    #22
    May 2008
    26 Post(s)
    Here's the new sensor I got on eBay, the guy claims it's genuine VW Audi but I wouldn't know if it's a fake or not. different design to the one Tazman photo' earlier in the thread
  3. Re: Air con G395 sensor no vaultage help please
    #23
    Aug 2012
    north west
    Thanks for all your help guys, it turned out to be 2 faults. One being a faulty connection in the LH door pillar and two the new sensor I got of ebay was a dud, replaced it with an original part now I'v got ice cold air con. The moral of the story is never buy rubbish off ebay!!
  4. Re: Air con G395 sensor no vaultage help please
    #24
    May 2008
    26 Post(s)
    Oops!
  5. Re: Air con G395 sensor no vaultage help please
    #25
    Jul 2012
    Kent
    Yup the new sensors look like that, all Ali so they don't split....
    As for ebay, well you got to use a reputable seller, I had no issues thankfully ��
    Regards.
    2007 3.0 tdi S-Line Avant.
    20 inch RS alloys, F/r park distance,S-Line leather, colour coded All road side skirts, Xenons
    Luv it !
  6. Re: Air con G395 sensor no vaultage help please
    #26
    May 2008
    26 Post(s)
    So this is my original fit G395 on my 2007 car (3.2 fsi Allroad) and I guess it looks the same as everyone else's. I can get my hands down there easily enough, but I can't see how a normal length spanner can get onto it without taking the bumper off, and even if I could solve that with a short spanner or pliers, etc then I have no idea how you could unplug the connector from the back side unless you unscrewed the sensor then pulled it forwards towards the radiator and unplug the connector afterwards. Any tips welcomed!
  7. Re: Air con G395 sensor no vaultage help please
    #27
    Jul 2012
    Kent
    Will try again on this pc ! Lol, that small stabilizer bracket between the bumper. and headlight can be removed, then the plastic shield can be pulled to one side ( from memory you need to remove the torx screws in it, fiddly but doable ), then I used a small lump of wood to make the gap bigger between the bumper and headlight, which gives you room to get a spanner in there.
    Be gentle on the fitting, it's soft alu, once it's just past handtight, stop, as the washer seals on a parallel shaft.
    Fiddly ,but I did it this way without removing the whole damn bumper
    HTH
    Luv it !
  8. Re: Air con G395 sensor no vaultage help please
    #28
    May 2008
    26 Post(s)
    Quote Originally Posted by _Tazman_ View Post
    HTH
    Thanks for the info Tazman, I will give it a go. One of those things which looks impossible but if you know how then clearly there is a way. Might get a chance to try this weekend.
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 0
    Last Post: 27-11-2013, 09:36 PM
  3. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  4. Question Bora - Engine judder when driving - MAF sensor, temp. sensor or ABS fault??
    By Christo3000 in forum Bora - 1998 - 2005
    Last Post: 20-06-2011, 05:29 PM
  5. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
