Thread: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
  1. Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    Feb 2017
    Long post warning!
    Ever since buying the Audi a couple of months ago now it's been one thing after another, I basically bought a complete melon I think. I can't help but love and hate it at the same time, my heart bought the car but now my head hates it for all of its issues etc. So if anyone can offer advise etc that would be great.
    Most noticeable issue is the vibration in 6th gear. It can be quite loud depending on the revs and my speed and after about 90mph it gets quite quiet although as soon as I decelerate it gets louder. It's only in 6th gear although in 5th gear you can sometimes feel a complete juddering throughout the car. I figure it's likely some kind of rotation vibration noise? It feels like I can feel the vibration from under the car but not sure where it's actually coming from. The noise gets faster with speed and slows down and is a little quieter when I decelerate. It doesn't go as quick as the wheels for instance it's quite a steady vibration sound if that makes sense? I'm struggling to find any definite solution to it and everything I've found so far leads to expensive fixes but no guaranteed results so I'm really hoping someone has an idea. The history of the car shows that the flywheel was changed back in oct 15 but don't have too much other history.
    Other symptoms, possibly relevant but I'm not sure..
    It's had an overboost issue and I've had the boost hoses popping off from the intercooler. I did the Mr muscle clean on the turbo and it hasn't gone into limp mode since but it does feel suffocated sometimes and like its being held back.
    In the first few gears it was very kangaroo like as if I was a brand new driver driving in first gear? But it'd judder/kangaroo if I tried remain at the same speed, only when I flawed it would it stop and it wouldn't do it on every journey, just some. I changed the fuel filter which was saturated, completely black. The service light has been on since I got the car and I don't know how long it's been on before that. It's been sat for a long time too. Since changing the fuel filter it hasn't done any major kangerooing although I feel paranoid I can feel it ever so slightly but that could just be me?
    I took the egr and inlet manifold off and gave them a good clean. The manifold gasket is shot and needs replacing. I also found coolant in there too! Not a good sign I know? It wasn't a lot of coolant but on the rest of the head (not sure if that's the correct term) it has white deposits that look as though they'd need sanding off to remove as if moisture has been getting in there?
    I removed the cylinder head to inspect the gasket as its leaking a bit around the edges and everything was caked in oil, is this normal? I know there should be some oil in there but the glow plug housings etc were drowning in it.
    I don't know which needs to be my main worry but the most significant one to me at the mo is the noise in 6th gear, it feels like everytime I'm driving it I'm damaging it even more.
    Any help and advise would be greatly appreciated!
    Apologies for the long post. I'm arranging to get it scanned as soon as I can to see if that reveals anything more.
    Thanks in advance..
  2. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    New Forest
    80 Post(s)
    Here's the VCDS scan of the A3, with a few faults if any one can throw some light on it.
    Sunday,23,April,2017,19:58:40:41500
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    Ross-Tech: Home
    VIN: WAUZZZ8Pxxxxxx License Plate:
    Mileage: 224130km-139267mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 7D
    VIN: WAUZZZ8Pxxxxxx Mileage: 224130km-139267miles
    01-Engine -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 7000
    Revision: 12345678 Serial number: AUX7Z0EDFN501W
    Coding: 0000172
    Shop #: WSC 06314 000 00000
    VCID: 63C572AEA2F7A45994-8036
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0023170
    VCID: 72EB07EA6D0D3DD1EF-8026
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH17 0260
    Revision: 040041 Serial number: 8P0820043P
    VCID: 3979F0C670FB8E89EE-806C
    1 Fault Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 223515 km
    Time Indication: 0
    Date: 2017.04.14
    Time: 10:32:40
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H44 1102
    Revision: 00H44000 Serial number: 00000002339585
    Coding: E5885F07A214100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408F9D221321DF41A9-8014
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH11 0050
    Coding: 00150573
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W001CVLL
    Coding: 0071612
    VCID: 479D863E360FE87968-8012
    Subsystem 1 - Serial number: 63328RB400D4D1C6R
    Subsystem 2 - Serial number: 63428RB400DAAB98/
    Subsystem 3 - Serial number: 63528RB400D4D17BT
    Subsystem 4 - Serial number: 63628RB400DAABF41
    Subsystem 5 - Serial number: 63729RB400D26892N
    Subsystem 6 - Serial number: 63829RB400D2681AO
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000012
    VCID: 78FF35C20B715781D1-802C
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 224DED06008008
    Coding: 0005413
    Shop #: WSC 00581 067 57207
    VCID: 377DF6FE46EF98F918-8062
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 201434 km
    Time Indication: 0
    Date: 2014.12.29
    Time: 05:58:44
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000105C028369
    Coding: BD0F0B4007000101
    VCID: 2B55DA8E8AA72C196C-807E
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 2D51D496B4B3222972-8078
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0EDFN501W
    Shop #: WSC 13425 002 1048576
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000632
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 3467C1F2579973E13D-8060
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000186D288505489AC63300
    VCID: 79F930C6307B4E89AE-802C
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000632
    VCID: 41899826182BD649A6-8014
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H58 0460
    Revision: 23S Serial number: AUZ5Z4E6167489
    Coding: 0021201
    Shop #: WSC 65337 000 00000
    VCID: 6FED0E9E7E3F103900-803A
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End-------------------------(Elapsed Time: 01:42)--------------------------
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  3. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    New Forest
    80 Post(s)
    I don't think this is anything to do with the three fault codes. I've had a look on the Ross-Tech site and Audiworld and none of the three fault codes would cause the vibration. Have you checked the wheel alignment? Reading this thread Vibration / judder on acceleration - esp in high gears when engine under load - Page 3 where similar problems were caused by wheel alignment.
    Pro Tyre in Ferndown have always done a free check for me (and charged to do the alignment) and they're part of Micheldever Tyres which isn't a million miles from Bordon/Salisbury.
  4. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    1834 Post(s)
    Quote Originally Posted by footychick View Post
    You mean the cam cover?
    Yes, it should be drenched in oil in there
  5. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    Feb 2017
    Quote Originally Posted by ragebe View Post
    I don't think this is anything to do with the three fault codes. I've had a look on the Ross-Tech site and Audiworld and none of the three fault codes would casue the vibration. Have you checked the wheel alignement? Reading this thread Vibration / judder on acceleration - esp in high gears when engine under load - Page 3 where similar problems were caused by wheel alignment.
    Hmm interesting, I can't see anything from the fault codes either that seems to relate much to the symptoms although it's very good to know about them.
    Anything has got to be worth a go at this point. I remember reading that guys thread a couple of times hoping I won't be going through the same expense with my diagnostic procedure! Thanks again for the scan, ragebe!
    Sent from my HTC One M8s using Tapatalk
  6. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    Feb 2017
    Sorry, yes. I'm not fully up on the proper names of everything but that picture is exactly what I saw and that's reassuring hearing that, thank you Crasher.
  7. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    Feb 2017
    It did have a lot more oil on it that on those pictures however, is that still OK?
  8. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    1834 Post(s)
    Yes, as long as it was not dirty and sticky but there is a huge supply of oil up there to 16 followers with hydraulic adjusters and two cams, 4 rocker arms and injector springs plus splash lube for the valve springs.
  9. Re: Where do I start?.. Audi a3 S Line Quattro tdi (BKD) problems.. big problems??
    Feb 2017
    Really good to know! Maybe something that isn't wrong with it then
  1. Audi A4 Avant 1.9 TDi cold start problems
    By frenchuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2014, 04:15 PM
  2. Audi A3 2.0 TDI Sport S line problems
    By fm86 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-04-2012, 08:49 AM
  3. Question 52 - Audi a4 B6 TDI 130 - Cold start problems
    By dhammerton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-12-2008, 12:11 PM
  4. Audi A4 non start problems(intermittant)
    By WestgateMotors in forum Chat - Anything with wheels
    Last Post: 02-04-2008, 10:00 PM
  5. A4 Quattro - Cold Start Problems
    By Gogzie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-01-2007, 10:47 AM
