Thread: Power steering pump problem
Results 1 to 10 of 14
  1. Power steering pump problem
    May 2015
    Co. Meath, ireland
    Evening all. My wife s A4 2.0tdi(143ps) 2010 with 103k miles has been diagnosed by her mechanic with a faulty power steering pump. This was his initial diagnosis and he subsequently confirmed this with Audi computer. My concern is (I m not a mechanic) there was no classic p.a.s pump problems like screeching when turning wheels or steering feeling heavy when turning. With the bonnet up there is a noise coming from alternator region(pulley?) and when driving there is a whine which sounds like a bearing noise. This whine stays regardless of speed. It s an expensive fix if it's the pump so would like to be certain mechanic got it right. Thanks in advance
  2. Re: Power steering pump problem
    1837 Post(s)
    Woooohh, how can the diagnostics monitor a fully hydraulic non diagnistic connected system? Only an electro hydraulic (Polo 9N) or fully electric system (A4 type 8K 2013>) can perform diagnostics and fully electric systems don't have a pump! The optional (rare) servotronic system has some electronic control but single wire and no feedback
  3. Re: Power steering pump problem
    May 2015
    Co. Meath, ireland
    Good night to you Crasher, and thanks for your interest. As I mentioned I have little or no mechanical knowledge so your reply left me scratching my head a bit. Could a power steering pump be bunched and yet not show any of the classic symptoms? Thanks again, Eoin
  4. Re: Power steering pump problem
    Jul 2015
    Staffs
    46 Post(s)
    I would take it elsewhere.
    Does the noise increase when the steering is under load? A/C on?
    Sounds more like a pulley, idler or tensioner issue.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: Power steering pump problem
    May 2015
    Co. Meath, ireland
    Quote Originally Posted by rowdy-999 View Post
    Thanks Ian. He heard a whine I described above when driving the car and diagnosed pump problem. Audi laptop confirmed this allegedly. No, noise does not increase when steering under load.
  6. Re: Power steering pump problem
    Pembrokeshire
    22 Post(s)
    be lovely to know what code the whine generated ?
  7. Re: Power steering pump problem
    Mar 2017
    Quote Originally Posted by Brennane21 View Post
    What crasher is saying is that the power steering pump in your car has no electrics, so it is 100% impossible for the computer to show a power steering fault. Basically the machanic is talking a load of crap. Take it to somewhere with more knowledge / a better mechanic.
    1 1 0
  8. Re: Power steering pump problem
    May 2015
    Co. Meath, ireland
    Cheers Ben, again apologies for any lack of technical know-how. That makes sense now. Wife spoke to mechanic this morning. He said bearings were gone in the pump. Would that not cause screeching in steering or heaviness in turning wheel? There were none of those symptoms. Going to get a second opinion this evening. Thanks again, Eoin
  9. Re: Power steering pump problem
    1837 Post(s)
    Power steering pump failure on VAG vehicles is extremely rare, I think I have done two in the last 10 years and one was on an ancient Audi Coupe 20v.
  10. Re: Power steering pump problem
    May 2015
    Co. Meath, ireland
    Anyway lads I got a second opinion on the whining noise and has been diagnosed as a wheel bearing in the front of car. So much for first mechanic! Thanks for the support.
  1. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  2. Power Steering Pump
    By iainbo in forum The Commercial Range
    Last Post: 26-05-2010, 12:38 PM
  3. Question Power Steering Pump
    By terrynic in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2009, 10:28 AM
  4. Power steering pump / belt problem tdi
    By Kingfisher1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-08-2008, 04:59 PM
  5. power steering pump
    By wax in forum Audi A4 - Archive Topics
    Last Post: 08-12-2006, 05:40 PM
