Thread: Broken/Smashed Rear Control Arm - Help [Photos]
Results 1 to 10 of 20
  1. Broken/Smashed Rear Control Arm - Help [Photos]
    Aug 2016
    Stoke
    Front passenger side rear control arm is completely smashed out of the joint, you can see the bushing. I've attached some photos to demonstrate.
    Firstly, can the car be driven? I'm aware it can't be driven particularly safely but could it be transported say a few miles, or is there a real chance of the wheel buckling? Perhaps a stupid question...
    Secondly, how hard, considering it's already smashed out would it be to replace? Would I need any specialist tools or just spanners/sockets and could I simply whip off the wheel, get a second hand part off eBay and drop it in? Does a replacement need pressing?
    Photos:
  2. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Pembrokeshire
    22 Post(s)
    ouch, what did you hit to do that..
    no, dont drive it. get it recovered.
  3. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Aug 2016
    Stoke
    Quote Originally Posted by zollaf View Post
    Partner hit a curb, very very hard. It's trashed the wheel as well (albeit cosmetically) and blew the side airbags. I drove it a short distance and have since had it low loaded home. The question is whether I take it to a garage (i.e. drive it) or do it on my drive?
    With it being smashed out like that, i figured it would be quite easy to replace, but it's only easy if i don't have to press a new one in because i don't have the ball joint press tool etc?
  4. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Pembrokeshire
    22 Post(s)
    you may also want to get the alignment of the front subframe checked if it was hit that hard, may well of bent something else. needs a proper inspection first by a qualified person in the air on a ramp.
  5. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Aug 2016
    Stoke
    There doesn't appear to be anything visibly, but agreed. I think the rear control arm took most the impact but It'll need looking at. If I can put the new part in then I can at least drive it to get it up in the air and see if anything else is bent.
    The bigger thing is getting that part replaced and whether I can do it with normal tools? I might whip the wheel off, have a look.
  6. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Pembrokeshire
    22 Post(s)
    well its only a bolt at the back and a stud should be left in the hub that should knock out although you may need a splitter of some sort to get it out.
  7. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Aug 2016
    Stoke
    Might have a look this evening then. Not a good day tbh. Not a good day at all.
    Can see this almost writing off the car. The airbag situation is enough to put me off as that's not as easy a job I imagine.
    I'd prefer not to buy any more tools as it's all time I guess. I might get a second hand one ordered off ebay.
    I'm right in thinking this is the same one?
    http://www.ebay.co.uk/itm/AUDI-A4-co...gAAOSw32lYn4gr
  8. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Pembrokeshire
    22 Post(s)
    yes, the airbags are the biggest thing to put right, new bags, sort the ecu, can be costly. the arm is well cheap in comparison.
  9. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    Aug 2016
    Stoke
    Yup. Nightmare. That and the fact an entire mug of coffee flew around the cabin of the car.
    Am I Right in thinking this is the arm?
    ..AUDI A4 convertible B6 Front passenger LH control arm suspension arm wishbone | eBay
  10. Re: Broken/Smashed Rear Control Arm - Help [Photos]
    scotland
    26 Post(s)
    The rear arm needs that side of the subframe dropped to retrieve the bolt, just three bolts to do that though. Easy enough, breakers for the replacement airbags.
  1. MMI control knob broken
    By N22LLO in forum Audi A6 - C7 Forum - 2011-
    Last Post: 30-08-2017, 02:48 PM
  2. Question Rear bushes gone....?? Photos attached.
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-07-2011, 04:42 PM
  3. Help, please. Rear bumper smashed!
    By bodmin1 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-12-2010, 12:02 PM
  4. Demist control broken
    By Steve Ryder in forum The Commercial Range
    Last Post: 05-02-2010, 07:34 PM
  5. Replies: 17
    Last Post: 06-06-2008, 02:08 PM
