Thread: Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
  1. Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
    Apr 2017
    On Wednesday night I was pulling away from traffic lights when I got the error: Gearbox overheating, please adjust driving style. I had only been driving for about 20 minutes and was only in second or third. It wouldn't get out of second gear and wouldn't go above 15-20 mph. I didn't try to force it to change up with the paddles and I quickly parked up.
    I came back to it in the morning and drove perfectly happily to the nearest dealer. This morning they called me to say they can't see the fault and recommended a gearbox oil change. I can see that the gearbox oil was done at 44k and it's now at 67k. Should I be doing it again? They want 250 which sounds steep.
    Advice appreciated! Many thanks
  2. Re: Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
    Feb 2016
    Blaydon, North east England
    12 Post(s)
    I would get your oil changed, its the first step and 250 sounds about right.
    2012 A6 Avant SE 3.0TDi Multitronic
  3. Re: Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
    Jan 2016
    Merthyr Tydfil
    13 Post(s)
    I'm sure on the Audi website it's a fixed price at 225......
  4. Re: Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
    Apr 2017
    Thank you for the replies.
    I have just had the following message from Audi via their online system:
    looked a bit further into this and there is a TPI (2022497/20) for this fault which states requires a new printed circuit for the mechatronics!!! there are other TPI's for faults including a SW update so advise new printed circuit and SW update then re-check
    They want 1,020 for the PCB... is this a common problem?
  5. Re: Gearbox Overheating - 2012 A6 S-Line 3.0 TDI Quattro
    Apr 2014
    Derby
    16 Post(s)
    The gearbox has a fluid cooler which is linked to the coolant system. Mine malfunctioned, and was replaced, could be that, a scan would show it up. They should fail open, so always cooled.
    2017 Audi A6 Avant BiTdi
    2008 BMW Z4M Roadster
  1. Replies: 4
    Last Post: 29-10-2016, 11:55 AM
  2. AVANT 2.0 TFSI S Line S Tronic Quattro gearbox warning
    By SeGMENT in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2016, 09:48 PM
  3. Newbie here looking for info A4 2L TFSI Quattro S Line 2012
    By Kbradan in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-04-2014, 10:44 AM
  4. 2012 A5 s-line wheels for 2008 A4 S-line
    By sacha35 in forum Wheels and Tyres
    Last Post: 04-11-2012, 08:30 PM
  5. RS4 front grill for an A4 3.0 tdi Quattro S-line Black edition - 2012 facelift
    By beachgang in forum Body Work, Body Styling and Body Kits
    Last Post: 18-06-2012, 05:17 PM
