Thread: 3.0 TDi [272ps] juddery on start up
  1. 3.0 TDi [272ps] juddery on start up
    Mar 2020
    Bridgnorth United Kingdom
    6 Post(s)
    When starting from cold my 3.0 [272ps] diesel is quite juddery/lumpy for about 20~30 seconds, this seems to have been slowly getting worse over the last few weeks - any ideas?
    Once up and running the car drives perfectly - no issues at all.
    Thanks in advance,
    Steve
    Misano Red 2018 Audi A6 Avant, 3.0TDi [272ps], Quattro, Black Edition, factory tow bar, tech pack, 20” twin spoke alloys, LED lights, S6 400mm Brembo six pot front brake upgrade, memory seats, panoramic roof....
  2. Re: 3.0 TDi [272ps] juddery on start up
    1840 Post(s)
    My expectation would be glow plugs but they should come up as a code so it makes me suspect an injector is either coming loose or leaking both of which are common problems.
  3. Re: 3.0 TDi [272ps] juddery on start up
    Mar 2020
    6 Post(s)
    If it were an injector coming loose, would it not do it all of the time?
  4. Re: 3.0 TDi [272ps] juddery on start up
    Aug 2018
    Swindon
    22 Post(s)
    Quote Originally Posted by Stevie Wonder View Post
    can't answer specifically about audi's as I'm new to them .. but certainly the injector heats up PDQ and will expand and possibly seal any leaks... think about the temps/pressures inside a cylinder !! If it is working loose it will only getw orse overtime .. so worth a check anyway
    2014 Audi A6 Allroad (C7, 245bhp)
  5. Re: 3.0 TDi [272ps] juddery on start up
    1840 Post(s)
    Only when the bolts fails and the injector blows out taking the fuel rail with it. Sometimes as a clue, a tar like goo will come out of a drilling at the front of the head and drip onto the exhaust manifold.
  6. Re: 3.0 TDi [272ps] juddery on start up
    Mar 2010
    Derry ireland
    60 Post(s)
    The pre glow & after glow activates the glow plugs via engine coolant temperature sensor reading The very most likely cause of your problem
  1. Question Juddery Braking on 2012 V6 Diesel Phaeton
    By A.J in forum Phaeton
    Last Post: 20-06-2014, 12:24 AM
  2. Creaky or juddery electric folding mirror
    By boof in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-05-2013, 03:47 PM
  3. Question Nissan micra not used for a month. Juddery breaks
    By Igloo in forum Chat - Anything with wheels
    Last Post: 19-02-2013, 09:48 PM
  4. Please Help Juddery Passat auto 2.0 TDI
    By caby in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2009, 05:28 PM
  5. juddery tick over on 2.0TDI
    By Matt B in forum Chat - Completely Off Topic
    Last Post: 13-02-2007, 10:52 AM
