Thread: 1.8 VRS Overheating !!
  1. 1.8 VRS Overheating !!
    Jan 2015
    My 1.8VRS has not stopped overheating after I changed the head gasket. Have also changed the fan Relay, thermostat and both heat sensors. Any suggestions?
    Sent from my CPH1701 using Tapatalk
  2. Re: 1.8 VRS Overheating !!
    Dec 2014
    Bedford
    42 Post(s)
    Water pump? . Impeller broken?.
  3. Re: 1.8 VRS Overheating !!
    Jan 2015
    Will check it today... Thnx
  4. Re: 1.8 VRS Overheating !!
    Dec 2014
    Bedford
    42 Post(s)
    Usually very little coolant moving through the overflow pipe back to the header tank with the rev's held up...is a good sign of a broken water pump.
  5. Re: 1.8 VRS Overheating !!
    Jan 2015
    It is the water pump.. Kind of hard to rotate the rotor also the rotor is loose and aluminum housing corroded.
    Will post after fixing.
  1. overheating
    By partridge911 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2010, 07:43 PM
  2. Please Help Overheating car - tried everything
    By AZA in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-10-2009, 10:36 AM
  3. 1.8L tt Overheating
    By hillqm in forum TT - 8N Forum - 1998 - 2006
    Last Post: 22-07-2009, 12:10 PM
  4. Question A4 overheating when air/con is on
    By shelfside19 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2008, 03:28 PM
  5. A4 TDI 130 overheating and no hot air!!
    By shane123321 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-01-2008, 04:51 PM
