Thread: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
Results 1 to 10 of 15
  1. VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Feb 2017
    Hello,
    I'm desperately in need of finding out what is wrong with my Audi A3 8p s line Quattro.
    If anyone could do a full scan on it that would be great, obviously beer tokens or such like will be given!
    I'm usually around Bordon in Hampshire at the weekends, not too far from Basingstoke, Farnham etc or Salisbury in Wiltshire during the week.
    I have looked at the users map but I don't have enough posts yet to be able to private message anyone.
    Thank you in advance!
    Hannah
  2. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    New Forest
    80 Post(s)
    I'm not too far from Salisbury (western side)
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  3. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Apr 2014
    I'm in godalming Surrey near Guildford
  4. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Feb 2017
    Thats great, not too far. Would you be around at the weekend at all?
  5. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Feb 2017
    Ragebe you have too many inbox messages lol
  6. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Apr 2014
    I'm around Sunday if that's any good
  7. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    New Forest
    80 Post(s)
    Quote Originally Posted by footychick View Post
    I always get around to reading them in the end
  8. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Feb 2017
    I cant reply to your message as its saying you have too many!
  9. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    Feb 2017
    Michaelhare are you still around today? Bit short notice so no worries if not!
  10. Re: VCDS User needed in near Bordon in Hampshire or Salisbury in Wiltshire Please
    New Forest
    80 Post(s)
    Here's the scan (it's also in the A3 forum)
    I've no idea what this fault is:
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 224DED06008008
    Coding: 0005413
    Shop #: WSC 00581 067 57207
    VCID: 377DF6FE46EF98F918-8062
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 201434 km
    Time Indication: 0
    Date: 2014.12.29
    Time: 05:58:44
    Ross-Tech says: http://wiki.ross-tech.com/wiki/index...ossible_Causes
    Sunday,23,April,2017,19:58:40:41500
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    Ross-Tech: Home
    VIN: WAUZZZ8Pxxxxxx License Plate:
    Mileage: 224130km-139267mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 7D
    VIN: WAUZZZ8Pxxxxxx Mileage: 224130km-139267miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 7000
    Revision: 12345678 Serial number: AUX7Z0EDFN501W
    Coding: 0000172
    Shop #: WSC 06314 000 00000
    VCID: 63C572AEA2F7A45994-8036
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0023170
    VCID: 72EB07EA6D0D3DD1EF-8026
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH17 0260
    Revision: 040041 Serial number: 8P0820043P
    VCID: 3979F0C670FB8E89EE-806C
    1 Fault Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 223515 km
    Time Indication: 0
    Date: 2017.04.14
    Time: 10:32:40
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H44 1102
    Revision: 00H44000 Serial number: 00000002339585
    Coding: E5885F07A214100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408F9D221321DF41A9-8014
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH11 0050
    Coding: 00150573
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W001CVLL
    Coding: 0071612
    VCID: 479D863E360FE87968-8012
    Subsystem 1 - Serial number: 63328RB400D4D1C6R
    Subsystem 2 - Serial number: 63428RB400DAAB98/
    Subsystem 3 - Serial number: 63528RB400D4D17BT
    Subsystem 4 - Serial number: 63628RB400DAABF41
    Subsystem 5 - Serial number: 63729RB400D26892N
    Subsystem 6 - Serial number: 63829RB400D2681AO
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000012
    VCID: 78FF35C20B715781D1-802C
    Coding: 0005413
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 201434 km
    Time Indication: 0
    Date: 2014.12.29
    Time: 05:58:44
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000105C028369
    Coding: BD0F0B4007000101
    VCID: 2B55DA8E8AA72C196C-807E
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 2D51D496B4B3222972-8078
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0EDFN501W
    Shop #: WSC 13425 002 1048576
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000632
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 3467C1F2579973E13D-8060
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000186D288505489AC63300
    VCID: 79F930C6307B4E89AE-802C
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000632
    VCID: 41899826182BD649A6-8014
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H58 0460
    Revision: 23S Serial number: AUZ5Z4E6167489
    Coding: 0021201
    Shop #: WSC 65337 000 00000
    VCID: 6FED0E9E7E3F103900-803A
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End-------------------------(Elapsed Time: 01:42)--------------------------
  1. VCDS user in Wokingham, Berkshire - help needed with new RNS-e
    By berrick in forum VCDS - Users Locations
    Last Post: 18-04-2020, 11:56 PM
  2. ESP Fault see owners manual...... Wiltshire/Hampshire border
    By simmo0020 in forum VCDS - Help Requests
    Last Post: 20-04-2017, 09:22 PM
  3. Replies: 0
    Last Post: 17-05-2011, 06:18 PM
  4. vag-com/vcds user needed south manchester .2005 golf 2.0 tdi mkv..
    By joseph76 in forum VCDS - Help Requests
    Last Post: 25-04-2010, 05:25 PM
  5. VW Audi Specialist in Salisbury Wiltshire
    By quantumowner in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 14-01-2009, 04:39 PM
