Thread: juddering on accelleration
  1. juddering on accelleration
    May 2014
    bradford, west yorkshire
    hi all,
    i have just got a 2004 a3 2l tdi very cheap but it come with a judder, when accellerating in 3 gear and upwards it judders until it get up to speed when holding it at a constant speed it is fine, i have been told it could be the flywheel but is there anyway to check this before i go out and buy a new one and it turns out not to be the clutch at all. a complete clutch and flywheel was fit at 90000 it as now done 121000
    thanks for any advise
  2. Re: juddering on accelleration
    Dec 2007
    8 Post(s)
    Unless the clutch was abused,or faulty,or incorrect type fitted,it should be good for another 100k miles at least,if the mileage is correct.
  3. Re: juddering on accelleration
    May 2014
    is there any way that i can check the clutch myself baring in mind i am far from being a mechanic are there any tell tale signs
  4. Re: juddering on accelleration
    Dec 2007
    8 Post(s)
    I.M.O. There is no definite way of defining d.m.f. failure,even the experts can get caught out.
    The many symptoms of failure can be also produced by engine/drive line problems,which can make diagnosing clutch problems difficult.
    When I got my A3 It had a slight vibration in engine on tick over,it also had a vibration/drone at about 60 mph which could be reduced by releasing throttle a minute amount.
    When power was applied again the vibration/drone would reappear. The tick over vibration could have been mistaken for an engine misfire.
    When I changed the clutch there were broken springs in it.
    There were no other symptoms in my clutch to indicate problems ,but there could have be many as clutch problems can vary.
    The new clutch sorted out my problems.
    Can you find out how long your problem existed. and was it evident prior to last clutch replacement,as well as any more history available.
  5. Re: juddering on accelleration
    May 2014
    i cant find nothing about it unfortunately the lad i bought it off couldnt drive he bought the car and it was parked in a field for 18months, ive checked the mot history online and it hasnt had an mot since 2015 antil i got it done at the begining of this month and that is all i know
  6. Re: juddering on accelleration
    Dec 2007
    8 Post(s)
    Then if possible,try and get as many people familiar with your model to have a look / listen and give opinions
    to help you with deciding best course of action.
  1. S-Tronic Accelleration Lag
    By cma in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-05-2014, 07:11 PM
  2. No accelleration in low
    By Brian Impala in forum Golf MK4 - 1999 - 2004
    Last Post: 27-02-2013, 10:55 PM
  3. Please Help Loss of accelleration on 1.9TDi
    By barryoz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 11-01-2010, 08:31 PM
  4. judder under accelleration
    By daveyboy467 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-06-2009, 07:20 PM
  5. squeeling under accelleration
    By pugville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-01-2008, 06:08 PM
