Thread: New A4 Allroad - oil
Results 1 to 9 of 9
  1. New A4 Allroad - oil
    Feb 2017
    Chester
    Morning all,
    I have a new A4 Allroad (3.0 218) which has covered just over 3k miles since I picked it up. The car is now out of oil - dash warning light on regarding min oil lever.
    Surely this is excessive oil usage?
    Or, is this just bedding in?
    There is no oil leakage on the drive.
    Any ideas?
    JW
  2. Re: New A4 Allroad - oil
    May 2012
    Everywhere
    308 Post(s)
    What was the oil level when new ?
  3. Re: New A4 Allroad - oil
    46 Post(s)
    My old B8 A4 used oil up until 10k, after that it didn't use any more right up until I traded it in at 29k.
    My current Passat seems to be using a bit of oil too but again it has minimal miles on the engine.
  4. Re: New A4 Allroad - oil
    May 2009
    Rothienorman
    It's not out of oil, it's at it's minimum safe level. But I very much doubt Audi will say that is excessive oil usage anyway if it's taken 3000 miles to reach the minimum oil level.
    If you are concerned contact your local Audi dealer and get their opinion and at least then it should be noted that you've raised a concern and if it continues then you've got more history to back up your argument.
    How do you drive the car, like there's an egg under the throttle pedal or like it was stolen? Sometimes engines like a good thrashing to keep things working better, I used to see engines which always pootled about and they had greater issues with oil usage than engines which were worked harder.
    '06 A4 SE 140hp, who needs more than this??? Gone away to a better home
    '15 RS4 Avant, a few toys and accompanying fuel tanker. Gone away to someone who likes fuel stops.
    '16 A4 Allroad 3.0l TDI V6 272ps. Big hole in roof and plenty other toys to distract me.
  5. Re: New A4 Allroad - oil
    Feb 2017
    Chester
    Yes good point Mike - not out but at min level. I have now added the requested 1L. I drive a mixture of 'driving miss daisy' and also 'drive it like you stole it' so the car does get pushed. Most days it's 30m each way to work along a motorway. I have raised it as a concern with my dealer so will see what happens. May be a one off - just wanted to canvas opinion / thoughts.
    Cheers all
    JW
  6. Re: New A4 Allroad - oil
    May 2009
    Rothienorman
    I have heard on other forums that 1L per 1000 miles was used as a measure of heavy oil use! For me that's a joke but what do you do against the might of a big manufacturer... I'll be interested in how your engine continues to use oil, hopefully it stops/slows soon, mine is similar but not used that much oil, maybe 0.3L in 2000 miles.
  7. Re: New A4 Allroad - oil
    Feb 2017
    Chester
    Dealer reckons it's a bedding in issue and 'understandable' for a car in the 3-4000 miles arena. I have added the required 1L so will monitor. Fingers crossed it wont happen again. If it does, I will note here and badger the dealer!
    JW
  8. Re: New A4 Allroad - oil
    Jun 2014
    A, A
    I'm 6k in on my 2litre diesal and only used about a third of the oil. It was full on delivery though.
  9. New A4 Allroad - oil
    Sep 2016
    Västerås, Sweden
    Quote Originally Posted by JW_Chester View Post
    Morning all,
    Any ideas?
    JW
    I'm approaching 15000 miles(23500 km) since August 2016 with my Allroad also with 3,0 218.
    As of now I have refilled appr. 1,5 l oil after two "oil level warnings" since the car was new back in August.
  1. C5 Allroad to C6 Allroad?
    By Grimsby Ranger in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-07-2012, 12:01 AM
  2. What to look for on a C6 Allroad MMI
    By WesleyP in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-08-2011, 12:32 PM
  3. '03 Allroad
    By Patrician in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-06-2011, 12:02 PM
  4. a6 allroad
    By CraSH582 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2010, 09:42 AM
  5. Hi everyone!! New A4 Allroad
    By 20av30 in forum New Member Introductions
    Last Post: 11-09-2009, 09:36 AM
