Thread: Eos 2.0tdi BMM problem
  1. Eos 2.0tdi BMM problem
    Apr 2017
    I'm having issues with my eos... got fault code p2279 which is leak in air intake system, I have changed POV and checked the vac pipes but not fully..
    does anyone have a diagram for the vacuum pipes on the 2.0tdi Bkp engine please?
    thanks
  2. Re: Eos 2.0tdi Bkp problem
    1840 Post(s)
    BKP in an EOS! Err, no, it's a BMM.
  3. Re: Eos 2.0tdi Bkp problem
    Apr 2017
    Yes my appolagies it is not Bkp engine code it's bmm
  4. Re: Eos 2.0tdi Bkp problem
    1840 Post(s)
    18711 (P2279) - Leak in Air Intake System
    I can't remember ever seeing this on a TDI, the petrol AXX engine yes but TDI....
    If I had that, my first step would be to put my VAG1687 pressure tester on and look for leaks but this is quite a rare tool. However, many garages have smoke testing equipment so the procedure is to disconnect the hose from the air mass meter and seal this off with a plug and put air into the system through a port in the plug to detect leaks. The pressure applied MUST NOT exceed 0.5Bar.
    This is a petrol but it is the same test and tool, ignore the arrow.
  1. Audi A3 2.0TDi DSG - problem..
    By sarah1989 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-04-2014, 06:29 AM
  2. 3.0TDi - Possible engine problem
    By jdp1962 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-05-2012, 03:42 PM
  3. Important Audi 2.0tdi BIG problem. Please help
    By alanscottgraham in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-08-2011, 03:41 PM
  4. Please Help A4 2.0TDI Engine Problem
    By fancy a cuppa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-09-2010, 10:51 PM
  5. Problem with 2.0TDi + K&N Filter.....
    By mrbirchall in forum Audi A3 - Archive Topics
    Last Post: 27-06-2008, 01:13 PM
