Thread: Think its an engine problem! Help?
Results 11 to 20 of 31
  1. Re: Think its an engine problem! Help?
    Apr 2017
    Wigan, UK
    I need to stick with it, want to see how much damage. Just if i can get the last 2 bolts out of the back of the sump closest to the flywheel?
    Sent from my E6553 using Tapatalk
  2. Re: Think its an engine problem! Help?
    1841 Post(s)
    You won't get the sump off without lifting the engine or lowering the subframe.
  3. Re: Think its an engine problem! Help?
    Apr 2017
    Wigan, UK
    You a great help thank you, will have another dig at it tomorrow!
  4. Re: Think its an engine problem! Help?
    Apr 2017
    Wigan, UK
    Still having trouble with the last 2 bolts closest to the flywheel, ive read you need to turn the flywheel round to a point where you can access the bolts...but the engine is seized is there another way?
  5. Re: Think its an engine problem! Help?
    Pembrokeshire
    22 Post(s)
    a really long ball end allen key bit ? or a 1/4 inch 10mm on a wobbly bar depending on what bolts they are.
  6. Re: Think its an engine problem! Help?
    1841 Post(s)
    I have just taken the sump off a Golf 5 TFSI and you have to position the flywheel AND use a ball ended hex key. If my memory is right there are two cut outs on the back of the flywheel.
  7. Re: Think its an engine problem! Help?
    #17
    Apr 2017
    Wigan, UK
    Quick update, Ive manager to lift engine and drop subframe and got the sump off which is in good condition. The flywheel/clutch pressure plate seems to be in a mess! Has anyone come across this before or know whats caused it?
    Thanks for your help!
  8. Re: Think its an engine problem! Help?
    #18
    Mar 2017
    That's the springs inside your Dual Mass Flywheel (DMF) that you can see. They appear to have failed and totally ******* the flywheel itself. Looks like it's time for a new one. Probably need a new clutch while you're in there also. Be worth removing it and seeing if you can then turn the engine over by hand. It might be what is causing it to feel like it's seized.
    Have a look at this video, skip to 1:30 and you will see what I mean about springs inside the flywheel.....
    LuK DMF - design and function - YouTube
  9. Re: Think its an engine problem! Help?
    #19
    1841 Post(s)
    Yes I have seen that once or twice and it can make getting the flywheel off very difficult as the outer section can twist, lock and cover the bolt heads.
  10. Re: Think its an engine problem! Help?
    #20
    Apr 2017
    Wigan, UK
    Thanks thats a great help!
    While most things are off at the front and engine is hoisted, would it be best to access the flywheel and clutch from the front or bottom?
  1. engine problem
    By steve rollinson in forum New Member Introductions
    Last Post: 11-10-2015, 09:27 PM
  2. Help! 1.8t engine problem (stuck engine)
    By coyleben in forum 1.8T - Engine
    Last Post: 17-09-2010, 01:08 AM
  3. Question Engine problem - Engine speed sticks high / Unstable engine speed
    By sef-75 in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 09:52 PM
  4. 1.9 TDI 52 reg engine problem
    By bonerp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2007, 09:26 AM
  5. problem with my a4 1.8 adr engine
    By philg in forum New Member Introductions
    Last Post: 02-11-2007, 08:17 PM
