Thread: A7 transmission plug seized
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. A7 transmission plug seized
    Aug 2007
    Hook Hampshire
    10 Post(s)
    I decided to change the multitronic gearbox fluid today and found that the plug was very tight. I then used an impact gun to avoid damaging the T55 plug, but to no avail and the plug is now damaged. Incidently the replacement plug is T60.
    The big question is how do I get myself our of this problem and get the old plug out. Has anyone found a way to solve this.
    Audi A7 Dakota Grey, 3.0TDi 2wd, engine CLAB, Gearbox NKP, Comfort seats, parking system advance, advance key, MMI Nav plus, MMI touch, HUD, Mob phone prep high with on-line services, heated sports steering wheel, folding mirrors, garage opener, fine grain ash inlays. 110k miles
    Audi Q5, 3.0TDi Sline Plus engine CDUC, adaptive headlamps, high beam assist, black inlays, advance key, TPMS, parking sys advanced, 45k miles
  2. Re: A7 transmission plug seized
    Jul 2015
    Staffs
    42 Post(s)
    Well don't use an impact gun again..
    I would attempt to knock in an T60 bit, and some gentle heat around the plug.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: A7 transmission plug seized
    Nov 2010
    Shetland & S.Tyneside
    72 Post(s)
    Carefull how much hammering and persuassion you use on the plug, dont want to crack the alloy casing! Is there any where you can get a suction tube in and just leave the plug.
  4. Re: A7 transmission plug seized
    Aug 2007
    Hook Hampshire
    10 Post(s)
    Thanks for both responses. The plug has to come out because the filling procedure used the same drain exit to fill the gearbox which has a critical level for filling at a certain temperature.
    I was thinking of using heat but will think about it over the next week before I do an more work.
    Regarding the impact wrench. I dried using a bar but it was so tight I was worried about damaging the plug, hence I switched to the impact wrench.
    Somebody must have had the same problem and fixed it.
  5. Re: A7 transmission plug seized
    May 2014
    Darlington
    44 Post(s)
    Your best option here is just to remove the sump, you will need a new gasket and while your there you can also change the filter.
  6. Re: A7 transmission plug seized
    Mar 2017
    Weld a nut onto it, the heat will break the corrosion bond and it will come out easily. Easiest and best way to do it. Someone with a mig welder can do it for you in 2-3 minutes easy.
  7. Re: A7 transmission plug seized
    Pembrokeshire
    22 Post(s)
    or a bolt. i find its easier to weld a bolt on where you can get good penetration around the end, where its harder to weld into the middle of a nut, unless you use a big one, m18 or something similar. old cv joint nuts are great for this.
  8. Re: A7 transmission plug seized
    Aug 2007
    Hook Hampshire
    10 Post(s)
    I don't have a welder so will have to get a garage to do this. Being of aluminium construction, do I need to take it to a specialist.
  9. Re: A7 transmission plug seized
    Mar 2017
    Quote Originally Posted by shabazmo View Post
    The casing is aluminium, but I'm willing to bet the bolt is steel or stainless steel or similar and has become seized due to galvanic corrosion of different metals. As such, a normal mig welder will probably work, but if you can find a professional welder with a tig setup they will be able to weld to nearly any material and will have a better chance of success.
  10. Re: A7 transmission plug seized
    Aug 2007
    Hook Hampshire
    10 Post(s)
    Thanks Benten, I am sure the bolt is aluminium, otherwise the torq splines would not have got damaged. I will look for a tig welder.
  1. Question Low Transmission Fluid or Transmission Computer? Audi A4 2.0 ALT CVT
    By bchoonga in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2016, 02:41 PM
  2. Transmission control unit or transmission output sensor?
    By yase12 in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 29-08-2014, 08:24 PM
  3. Seized Handbrake
    By Lab Rat in forum Polo - Derby - Lupo - Fox
    Last Post: 12-03-2013, 07:13 AM
  4. TDi Turbo Seized!!
    By gregwillclark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2011, 09:35 AM
  5. Glowplug seized 2.5 tdi
    By Columbo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2010, 07:25 PM
