Thread: No Blower or Aircon
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. No Blower or Aircon
    Dec 2007
    Dudley, West Midlands
    It appears i have no Fan or blower at all on my A6 it is a 2006 3.0 TDI Quattro
    i have scanned it and there are several faults showing
    Sunday,09,April,2017,13:47:37:09784
    VCDS Version: 17.3.1.0 (x64)
    Data version: 20170320 DS270.2
    Ross-Tech: Home
    VIN: WAUZZZ4F37N044486 License Plate: AK56FFZ
    Mileage: 286390km-177954mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56
    61 62 72 76 77
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F0 910 409 A HW: 4F0 907 401 C
    Component: 3.0L V6TDI G001SG 0010
    Revision: --H03--- Serial number:
    Coding: 0011312
    Shop #: WSC 02334 785 00200
    VCID: 224BC906FDE9C950AB-8076
    2 Faults Found:
    012597 - Intake Manifold Runner Control
    P3135 - 001 - Lower Stop not Reached
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 23
    Reset counter: 255
    Time Indication: 0
    Date: 2017.03.27
    Time: 19:01:23
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 11.78 V
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Duty Cycle: 20.5 %
    005493 - Right Engine Mount Solenoid Valve (N145)
    P1575 - 001 - Short to Plus
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 255
    Time Indication: 0
    Date: 2017.03.29
    Time: 18:29:26
    Freeze Frame:
    RPM: 1932 /min
    Torque: 171.6 Nm
    Speed: 114.2 km/h
    Voltage: 13.76 V
    Bin. Bits: 1
    Bin. Bits: 1
    Bin. Bits: 1
    Readiness: 1 1 0 0 0
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 HW: 4F2 820 043 N
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000000299441
    Coding: 0001302
    Shop #: WSC 02325 785 00200
    VCID: 5BB5B4E29A03B898A8-800E
    4 Faults Found:
    01592 - Air Quality Sensor (G238)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:27
    Freeze Frame:
    Temperature: 27.0C
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:27
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:35
    01844 - Control Module for Fresh Air Blower (J126)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:42:47
    Freeze Frame:
    Temperature: 27.0C
    Speed: 0.0 km/h
    (no units): 28.0
    (no units): 214.0
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02335 785 00200
    VCID: 3169364AA80F62C822-8064
    Subsystem 1 - Part No: 4F2 910 113 A
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00139811
    Shop #: WSC 02335
    2 Faults Found:
    02745 - Bulb for Daytime Running Light; Left
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111011
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 105
    Time Indication: 0
    Date: 2017.03.27
    Time: 19:00:00
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 102
    Time Indication: 0
    Date: 2017.03.28
    Time: 15:43:00
    i have removed the air quality sensor and checked wiring, the wires seem ok, possibly faulty sensor.
    i have removed the control head, all the connectors were tight, and no wires seem damaged.
    so thought i would turn to the masters on here! anyone any idea what this is likely to be?
    when i start the car the econ light is on, i can press the button and it goes off then back on, no blowers at all, though heated seats and setup all seem to work.
    with the engine off the aircon and blowers will come on eventually and the econ light goes off if i press the button.
    any help would be appriciated.
    Regards Dean Warren. VCDS owner/user
    Audi A6 Avant 2.5 TDi (AAT 115BHP) 305k Sold
    A6 180 sport 2.5 TDi Quattro Avant 2001. Half Leather 160K New Cams Fitted @ 154K
    A6 C6 3.0 TDi Quattro S-Line Avant with Exclusive Leather SatNav Bluetooth AMI LED and Xenon's
  2. Re: No Blower or Aircon
    Dec 2007
    Quote Originally Posted by dean warren View Post
    Ross-Tech: Home
    61 62 72 76 77
    Coding: 0011312
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 23
    Reset counter: 255
    Time Indication: 0
    Date: 2017.03.27
    Time: 19:01:23
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 11.78 V
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Duty Cycle: 20.5 %
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 255
    Time Indication: 0
    Date: 2017.03.29
    Time: 18:29:26
    Freeze Frame:
    RPM: 1932 /min
    Torque: 171.6 Nm
    Speed: 114.2 km/h
    Voltage: 13.76 V
    Bin. Bits: 1
    Bin. Bits: 1
    Bin. Bits: 1
    Coding: 0001302
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:27
    Freeze Frame:
    Temperature: 27.0C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:27
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 67
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:41:35
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Time Indication: 0
    Date: 2017.04.09
    Time: 13:42:47
    Freeze Frame:
    Temperature: 27.0C
    Speed: 0.0 km/h
    (no units): 28.0
    (no units): 214.0
    Coding: 0013121
    Coding: 00064784
    Shop #: WSC 02335
    Coding: 00139811
    Shop #: WSC 02335
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 105
    Time Indication: 0
    Date: 2017.03.27
    Time: 19:00:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 102
    Time Indication: 0
    Date: 2017.03.28
    Time: 15:43:00
    These all come back when DTC's cleared.
  3. Re: No Blower or Aircon
    Sep 2016
    SE London
    Can't help you with the fault codes I'm afraid as I haven't bought a vcds yet....however last Christmas my fan blower packed in...indications were that when it did sometimes work I occasionally heard a whirring noise coming from the fan area...and it intermittently didn't work...often when I needed it most!!!
    I changed the fan blower and it worked fine after that. I recall reading that if your aircon light doesn't go out i.e. Working then it's something other than just the blower motor...that I can't help you with I'm afraid. There are far more experienced people that should hopefully chime in with advice.............. changing the motor wasn't too hard...the scuttle panel was an **** though.. anyway, on the bright side it's not too cold to need a heater and not too warm to need aircon ...
    sorry i I couldn't be of more use..
    yep just read that your light goes on and off etc so may just be the motor..
  4. Re: No Blower or Aircon
    Dec 2007
    Maybe, it does blow if the engine isn't running though, so think its possibly something else, may need to pull the front bumper off and check the pressure switch.
  5. Re: No Blower or Aircon
    Sep 2016
    SE London
    Yeah...if it's blowing well without it running then your probably right..mine didn't make a difference re running or not ...good luck hunting!
  6. Re: No Blower or Aircon
    Jul 2013
    37 Post(s)
    The G395 pressure Sensor is known to cause trouble when its on its way out.
    Remove the front plastic cover above the grill the sensor is on the passenger side.
    Dan
    2009/2010 2.0 TDIe SE
  7. Re: No Blower or Aircon
    Dec 2007
    Are they best replaced with genuine? Or euro car parts
  8. Re: No Blower or Aircon
    Jul 2013
    37 Post(s)
    Before you buy anything check that the wiring round the plug is ok and the pins are not corroded.
    As for Geniune or other i personally thinK VAG parts are of low quality, there advertising will say different.
    Dan
  9. Re: No Blower or Aircon
    Apr 2017
    wirral
    if your blower/fan is not working i would be checking the heater/blower resistor ,i have done lots of these on bmws with same symptons,although not on my q7,usually an easy job ,some call it a hedgehog,located inside the car around heater blower area ,google it for exact location.
  10. Re: No Blower or Aircon
    Feb 2015
    bedford & england
    i had the same issue where the motor fan stopped working and i was at my wits end with this as i had no heating for about 3 wks i found out with the help of these fantastic people on the forum the issue, the motor fan and the resistor packed up bought from ECP and was quite easy to fit apart from removing the scuttle panel.
    Change them two and you should be fine hope this helps
  1. Question A3 2010 - Aircon / Blower Unit Problem - Another One!
    By TJH392 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-12-2016, 12:43 AM
  2. Remove Blower From Blower Housing/ Replace Brushes
    By harry100 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-02-2013, 06:38 PM
  3. Blower Fan
    By master220 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2013, 09:57 AM
  4. Aircon/blower problems
    By smudge1101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-10-2010, 07:28 AM
  5. 1998 Sharan TDi front heater/aircon blower fan
    By DAVE ROBINSON in forum Touran - Sharan - Caravelle
    Last Post: 25-05-2010, 11:40 AM
