It appears i have no Fan or blower at all on my A6 it is a 2006 3.0 TDI Quattro
i have scanned it and there are several faults showing
Sunday,09,April,2017,13:47:37:09784
VCDS Version: 17.3.1.0 (x64)
Data version: 20170320 DS270.2
Ross-Tech: Home
VIN: WAUZZZ4F37N044486 License Plate: AK56FFZ
Mileage: 286390km-177954mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56
61 62 72 76 77
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 409 A HW: 4F0 907 401 C
Component: 3.0L V6TDI G001SG 0010
Revision: --H03--- Serial number:
Coding: 0011312
Shop #: WSC 02334 785 00200
VCID: 224BC906FDE9C950AB-8076
2 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Time Indication: 0
Date: 2017.03.27
Time: 19:01:23
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.78 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
005493 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Time Indication: 0
Date: 2017.03.29
Time: 18:29:26
Freeze Frame:
RPM: 1932 /min
Torque: 171.6 Nm
Speed: 114.2 km/h
Voltage: 13.76 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Readiness: 1 1 0 0 0
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F2 820 043 N
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial number: 00000000299441
Coding: 0001302
Shop #: WSC 02325 785 00200
VCID: 5BB5B4E29A03B898A8-800E
4 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2017.04.09
Time: 13:41:27
Freeze Frame:
Temperature: 27.0°C
02071 - Local Databus
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 67
Time Indication: 0
Date: 2017.04.09
Time: 13:41:27
00256 - A/C Pressure/Temperature Sensor (G395)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2017.04.09
Time: 13:41:35
01844 - Control Module for Fresh Air Blower (J126)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Date: 2017.04.09
Time: 13:42:47
Freeze Frame:
Temperature: 27.0°C
Speed: 0.0 km/h
(no units): 28.0
(no units): 214.0
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
Shop #: WSC 02335 785 00200
VCID: 3169364AA80F62C822-8064
Subsystem 1 - Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139811
Shop #: WSC 02335
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 6
Reset counter: 105
Time Indication: 0
Date: 2017.03.27
Time: 19:00:00
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 102
Time Indication: 0
Date: 2017.03.28
Time: 15:43:00
i have removed the air quality sensor and checked wiring, the wires seem ok, possibly faulty sensor.
i have removed the control head, all the connectors were tight, and no wires seem damaged.
so thought i would turn to the masters on here! anyone any idea what this is likely to be?
when i start the car the econ light is on, i can press the button and it goes off then back on, no blowers at all, though heated seats and setup all seem to work.
with the engine off the aircon and blowers will come on eventually and the econ light goes off if i press the button.
any help would be appriciated.
