Thread: DPF Light, Flashing Glow Plug Light & Engine Management Light on
Results 1 to 10 of 11
  1. DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Jan 2010
    telford uk
    Hi Guys,
    I have these lights on the dash and I cant get it checked for a code until after Easter, so I'm wondering if anyone can let me know what to expect.
    The car is a 2007 Golf GT 170 with 156k on the clock. I have done most of those miles myself with very few problems. The DPF light has occasionally lit up before at the weekend when I just pop around town. Then when I drive to work (35 miles) it always goes out, and stays out for weeks.
    This time it hasn't gone out on a journey and the engine management light has come on and the glow plug light is flashing and it's gone into limp mode. Like I said, as soon as I can I will get it in for a scan, but has anybody else had this issue? could it be a faulty sensor? or a knackered DPF. In my head those are the two extremes. I'm kind of committed to keeping the car for a bit as I've just had the clutch and dual mass replaced, and to be fair it runs like a swiss clock....until now that is.
    I have read the sticky, but just wanted to know if anyone has had 1st hand experience of this issue.
    Regards
    Steve
  2. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Apr 2017
    Grantham
    My spider senses are saying you need either a dpf clean or replacement
    Sent from my Lenovo YT3-X50F using Tapatalk
  3. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Mar 2017
    Had this on my A4 2.0TDI 170 last year, but it all started with a faulty EGR and engine management light. To fix my issue I replaced the EGR (plastic gears were broken, otherwise a clean would have worked), replaced the differential pressure sensor (as a precaution), added Wynns DPF cleaner and topped the tank with diesel, then went out and did a forced DPF regen with VCDS. DPF light has been out since.
    In your shoes I would clean the EGR, as there is no need to replace if not broken and do the same as what I did. I think my original DPF sensor was fine, but they are known for failing, so for £50 I replaced it, really easy to access on the A4, bolted to the bulk head.
  4. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Apr 2017
    Grantham
    Never considered the EGR being at fault, why is this affecting the dpf, my friend had to get a professional clean because the regent didn't work
  5. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Jan 2010
    telford uk
    It's the DPF. Would not respond to a forced regeneration so new one being fitted today. £350 + fitting.
    Sent from my SM-G925F using Tapatalk
  6. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Apr 2017
    Grantham
    Did you not consider a professional clean or was in knackered
  7. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Jan 2010
    telford uk
    Yes it's knackered.
  8. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Apr 2017
    Grantham
    Ouch I'm pleased I don't have one
  9. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Jan 2010
    telford uk
    Its my 2nd car it owes me nothing. I have no problem with things wearing out normally. I plan to get it to 300k miles. Just because I can.
  10. Re: DPF Light, Flashing Glow Plug Light & Engine Management Light on
    Apr 2017
    Grantham
    That's more than to the moon and back, well played I've only done 73k in my gti
  1. Please Help dpf flashing glow plug and eng management light on??
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2019, 09:52 PM
  2. Replies: 0
    Last Post: 26-01-2017, 09:18 PM
  3. Glow plug & Engine Management Light
    By wheels2014 in forum A1
    Last Post: 26-08-2015, 01:16 PM
  4. 2.0tdi 170 intermittent glow plug light and Engine management light.
    By nigedvd in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 19-06-2014, 10:14 AM
  5. Question DPF, glow plug and engine management light all showing
    By patel321 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-09-2013, 06:35 PM
