Thread: Flashing Glowplug Warning Light
  1. Flashing Glowplug Warning Light
    Aug 2009
    Olney, Uk
    Just had my Glow Plug warning light start flashing on the way home from work on my 2005 final edition avant (1.9 AWX engine). Has anybody seen this before? Does it mean anything else as a glowplug light coming on after a good 75 mile run doesn't seem to make much sense...!
    Any thoughts would be appreciated.
    Thanks.
  2. Re: Flashing Glowplug Warning Light
    7 Post(s)
    Engine management warning is via the glowplug light.
    A really common one is the brake light switch.... are your brake lights working?
    If yes, you will need the car scanned for faults.
  3. Re: Flashing Glowplug Warning Light
    Aug 2009
    Olney, Uk
    Quote Originally Posted by Col View Post
    Thanks Col, yes scanned it this morning (Autel 802) and it looks like I've not only got the 16955 implausible brake signal but also the 17664 G62 temp sensor open circuit (which seems to be another common one). Seem to remember having similar fun on a AVF powered B5 Passat so appears to be a regular VAG issue. Just need to check access so it doesn't encroach too much on my Easter break!
    Thanks again and happy holidays.
  1. Mk6 golf glowplug warning light flashing!!
    By craig_27 in forum Golf MK6 - 2009 - 2013
    Last Post: 13-01-2017, 11:42 PM
  2. help glowplug light flashing
    By tewy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 19-03-2012, 12:56 PM
  3. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  4. flashing glowplug light
    By a4driver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-07-2009, 06:42 PM
  5. Flashing Glowplug Light
    By corkycat in forum Chat - Anything with wheels
    Last Post: 05-01-2009, 12:54 PM
