01317 - Control Module in dash panel (J285)
i got this code after disconcerting the battery for a while every thing working good except the remote wont lock and unlock the car but manually using the key directly to lock and unlock its ok lock and unlock and the alarm arms but the led on driver door its illuminates about 30 seconds then flashes normally
i start auto scan
only the central locks wont access by the scanner i think its getting no power
i fund the driver floor wet i puled the ccm out under the carpet its little bit wet but no cortisone or rust on the ccm board or pins i cleaned any way by electric board spry cleaner
so every think ok except the
central locks wont access by the scanner and remote wont work
