Thread: Coding question mmi and facia swap
Results 1 to 10 of 13
  1. Coding question mmi and facia swap
    Sep 2011
    Sheffield
    Hi, just got replacement 5f module, spoke to a few people to help code with vcds, they all say they dont think they can copy codes of old module and paste to new one until Audi have removed component protection, is this true??some say that i dont need to code it only remove component protection?
    Also desperately trying to find instructions on net how to take front plastic face off my module and fix to replacement module, as i bought it without it??
    Any help would be highly appreciated thanks or if anyone know anyone up sheffield way that knows what yhey are doing
  2. Re: Coding question mmi and facia swap
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    If it's a new module it will probably need the dealership to remove the component protection, then you should be able to code it with vcds
    Sent from my Pixel using Tapatalk
  3. Re: Coding question mmi and facia swap
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by Cricket0310 View Post
    Good luck with those specialist around you, i am not fancy repeat myself you can do coding before or after, no matter really, you need to tweak in green menu after anyway to match all your car options, but probably local boys are aware of that! CP has nothing to do with coding or sw update, done MANY times with different modules!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  4. Re: Coding question mmi and facia swap
    Sep 2011
    Sheffield
    Its not brand new got it from ebay but new to my car i guess, should i stay clear from people who say they can do removal of component protection without going to audi, or will that work just as good, dont want to mess new unit up
  5. Re: Coding question mmi and facia swap
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I think if it's used component protection should already be removed. Maybe just connect it up and see what happens
  6. Re: Coding question mmi and facia swap
    Sep 2011
    Sheffield
    Local boys arent aware of much really mate, i told them what you advised gunnark but they dont understand.
  7. Re: Coding question mmi and facia swap
    Oct 2012
    Estonia
    64 Post(s)
    If you have your old module printout scan or similar, let them take coding from there and so to say manualy copy paste to the new one with vcds, after its fitted, dealer usualy will not do this! You can do this before or after dealer will remove component protection. Most of used units have still component protection, only few big sellers remove those before selling.
    Its my, dont use it
    :copy coding from old scan to new:
    Part No SW: 4E0 035 666 K HW: 4E0 035 666 C
    Component: H-BN-EU H52 0187
    Revision: -------- Serial number: 454I+0B7592073
    Coding: 01010001020681ED05000F1D000000010001
    Shop #: WSC 25712 136 13133
    VCID: 2E591061790C649
  8. Re: Coding question mmi and facia swap
    Sep 2011
    Sheffield
    Thanks mate, i really appreciate it,
  9. Re: Coding question mmi and facia swap
    Oct 2012
    Estonia
    64 Post(s)
    Whenever they done with coding, let them activate green menu(engineering) also, as you probably need to play there a bit, to get all function work under car-menu etc...
    Green menu activation:
    module 5F - adaption - channel 6 - change value to 1, save. Restart a system!
  10. Re: Coding question mmi and facia swap
    Sep 2011
    Sheffield
    I just managed to speak to a company who say they will code for me by connecting to vag server? will take few hours but new unit will be ready to use without going to Audi. I bloody hope so, they are not cheap will cost same as Audi 145 but will replace the face and swap the units also. Finally hope this is it!!, will keep u posted and thanks a million pal
  1. Idiot with a question! Engine swap ?
    By Sionr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-09-2016, 11:45 PM
  2. RNS-E coding question
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2013, 10:44 PM
  3. Key coding question
    By masonic in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2011, 10:59 PM
  4. Oh no, not this question again - Key coding
    By A6SE in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2010, 04:00 PM
  5. Engine swap question...
    By Glupage in forum Golf MK5 - 2004 - 2009
    Last Post: 20-07-2009, 04:29 PM
