Thread: a4 cabriolet roof clunking, rattle noise over bumps
  1. a4 cabriolet roof clunking, rattle noise over bumps
    Dec 2016
    Glasgow
    I've got this clunking noise from the front of my convertible roof where it latches to the window frame. The noise is only apparent when going over uneven ground, I have removed the plastic trim and if I put my hand in the mechanism i can feel the clunking.
    Just wondered if it's the central motor or the edge latch hooks moving slightly over bumps?
    I'm sure it's one of these points as with the roof down the noise is gone when driving.
  2. Re: a4 cabriolet roof clunking, rattle noise over bumps
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I wonder if the latches need a clean and grease up where they locate into the frame to ensure a good tight lock.
    If they have become dry over the winter they may be sticking and therefore not sitting 100 percent into the locks, worth a try and cheap and easy to do
    Stuart
  3. Re: a4 cabriolet roof clunking, rattle noise over bumps
    Dec 2016
    Glasgow
    I've greased the catches and also applied some rubber tape. What I think it could be is the rectangular block so I might try and put some felt or something in there too.
  1. Cabriolet roof latch rattle help?
    By A1EK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-03-2017, 10:33 AM
  2. rattle over bumps
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2013, 07:07 AM
  3. Please Help Clunking noise when engaging 1st gear then slight rattle in 2nd gear
    By tonnoir in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2011, 09:25 PM
  4. Please Help clunking over bumps
    By abbykyle1 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 08:56 PM
  5. golf tdi clunking over bumps
    Last Post: 20-02-2009, 04:02 PM
